Detecting settings
leifs
Detecting settings
by leifs » Sun Jul 08, 2012 9:05 pm
I'm struggling with a pano that is supposed to be a piece of cake. But there must be a checkbox somewhere that has to checked/unchecked to get it right. So I ask for suggestions.
case:
gigapano, shot with Oly E-M5 with Canon 400mm using Seitz VRdrive 2
1116 images shot in ORF (raw) transformed to tiff using Lightroom 4.1
APG 2.63 and 3.0alpha gives the same result
the problem:
in adjacent images where there are lots of CP's result in none CP's detected at all
in the example below image 686 and 687 should have a lot of CP's but have none !
anybody ?
leifs
Seitz VRdrive2
by gkaefer » Sun Jul 08, 2012 11:35 pm
using the v3alpha1 I could misconfigure autopano in any combination. I did not reach to get no single or any less CPs. (in any combination the CPs got created linke in screenshot...)
So I think its not the image. I didnt care EXIF data etc. I created the two "source" images by copy&paste from your screenshot. even so no single problem.
What I think its not normal that this row of images does not have any CPs to images one row bleow (so many images should have enough similar points to detect CPs, the water area its clear that no CPs are detected) . The distance from the rows seems to be equal, so in higher rows CPs are there, but not in the lower...
by testing settings I saw that using the lens disortion like you did brings maybe a corrected image but look to the form of the resulting image (second screenshot the detection result on bottom)... now imagine the same with the row below... I think the overlap of the images are now to small, no CPs can be detected. This does not explain in detail why the left and right image of the same row cant find CPs, but maybe autopano does here fail...
I would use the default gigapixel preset and I would let the lens disortion disabled. autopano takes images and squeezes, stretches and compresses the images to create a panorama so I would really not care about lens disortion on your kind of panorama.
by klausesser » Sun Jul 08, 2012 11:49 pm
leifs wrote:anybody ?
leifs
Hi leifs!
Sorry for asking - it didn´t come clear to me: did you use your head´s xml-files?
Guess you should hard-link all or some of the red dots to neighboured images and run local opt. each time.
leifs
by leifs » Mon Jul 09, 2012 10:35 am
klausesser wrote:Sorry for asking - it didn´t come clear to me: did you use your head´s xml-files?
Yes, I did.
That's why the images on the water is nicely put in place :-)
Rendering this as is creates a mess on land, since there are small offsets. Therefore the dots has to be connected, and I would like APG to do it.
leifs
Seitz VRdrive2
by klausesser » Mon Jul 09, 2012 12:55 pm
Yes, I did.
leifs
I see! Did you read the little tutorial Alexandre wrote for one of my cases some time ago regarding importing and optimizing:
http://www.autopano.net/wiki-en/action/view/Troubleshooting_Papywizard_Cases
leifs
by leifs » Mon Jul 09, 2012 2:20 pm
I have reread it, but can't find the case to be similar.
Now I have connected some images by hand, and it works fine. Lots of CP's.
I have also tried left-click and run "local geometry analyse" and work fine too.
But why do I have to do it by hand, image for image ? Thats not Auto-pano ! Why doesn't APG find these CP's during the detection, when it easely find them when don by hand ? Each "local geometry analyse" takes me 13 secs and there are a lot of connections to be made. Frustrating.
There must be a better way than this image-by-image-by-hand.
btw: now I'm using APG 2.63
below: the full pano detected, the CP's found by hand, the connections done by hand is blue
leifs
Seitz VRdrive2
by klausesser » Mon Jul 09, 2012 4:09 pm
leifs wrote:I have reread it, but can't find the case to be similar.
leifs
You don´t need to hard-link all - i realized that linking some images manually where a gap is most likely "triggers" enough of the others.
hankkarl
by hankkarl » Mon Jul 09, 2012 4:33 pm
If you uncheck "use grid position" and re-optimize (start from a pano you showed above, not from new) what happens to the unlinked pictures?
I suspect that this has to do with CPs getting put on the water instead of on land, and APG then cleaning them out because the grid is prefered.
Georg showed two renders of the images, one was rectangular, the other had severe pincusion. I would expect a rectangular render from two images takein with a 400mm lens. The pincusion was probably caused by bad CPs, and IMO waves give lots of bad CPs.
leifs
by leifs » Mon Jul 09, 2012 4:52 pm
The images were shot using the Canon 100-400mm f/4.5-5.6 L @400mm on a crop 2 camera, E-M5, so I would not expect much distorsions.
leifs
Seitz VRdrive2
leifs
by leifs » Mon Jul 09, 2012 6:54 pm
hankkarl wrote:If you uncheck "use grid position" and re-optimize (start from a pano you showed above, not from new) what happens to the unlinked pictures?
this is what happened :-|
leifs
Seitz VRdrive2
by AlexandreJ » Tue Jul 10, 2012 9:40 am
I don't know the reason, but it seems that calculations don't allow these links to be processed.
One idea : reduce the focal length to 600mm instead to 800mm.
Note : papywizard mode in 3.0 alpha 1 is a bit broken, just use 2.6.3.
leifs
by leifs » Tue Jul 10, 2012 1:49 pm
Round #5:
detection quality "high" gives me som more connection, but it takes hours
I connect the important images, mostly by "local geometry analyses"
it look allright, I only need to delete some CP's and optimize.
optimize mess up the hole thing !
dead end. hours wasted. back to square one :-(
leifs
below:
first image: after the optimize
second image: before the optimize
Seitz VRdrive2
leifs
by leifs » Thu Jul 12, 2012 7:11 pm
AlexandreJ wrote:One idea : reduce the focal length to 600mm instead to 800mm.
round #6
600mm. dead end
leifs
Seitz VRdrive2
leifs
by leifs » Thu Jul 12, 2012 7:21 pm
round #7
800mm, no lens correction, standard detection
this is the best APG can do Auto (I'm a bit dissappointed)
I connected the images with buildings, roads etc by hand, one by one.
100 x leftclick, local geometric analyses, next
APG happily find lots of connections and CP's this way. No problem at all.
Why didn't it find them in the first place, Auto ????????
It took me 36 minutes to shoot this 8.3 gigapixel pano and in the end I'm satisfied with the result.
But I'm not happy with all the hours it took to detect it.
With the prime lens, the precision of the VRdrive 2 and the XML it should have been a piece of cake, auto.
here it is
http://www.rundskuer.no/panotour/ulsteinvikframosvarden/virtualtour.html
leifs
below:
a piece of of the pano as detected. lots of missing connections
Seitz VRdrive2
