mikjoel wrote:Hello,
I've got a very strange problem when stitching panos. When I stitch pictures taken by my Olympus E330 all my panos seems to have a wrong aspect ratio, also the control points don't fit, also the program tells me that they are fine. All the control points have an offset off about half size of the picture. This happens only with pictures from the E330 - with my Canon or Olympus E30 all panos are ok. The Exif Data seems to be OK for the E330 pictures.
When stitching the panos the result is not acceptable ! Any Idea ( a picture which describes this behaviour better will follow in the afternoon )
The pictures show the control points with the offset
the pano after stitching
the pictures before stitching
and the preview window
mediavets wrote:mikjoel wrote:Hello,
Very strange.
Can we have access to these four images so we can try and stitch them?
hankkarl wrote:Try using detection set to low. It may be that you have a sensor with some differences between the pixels. If APP only uses lumiance for detection, it may pick up these paterns. detection set to low decimates the pixels and may smooth out the differences between pixels.
Also, running a smoothing filter on the files before stitching will eliminate the pixel differences, and show if I"m right or wrong.
mikjoel wrote:The pictures where taken in handheld "Auto Modus" with fixed white balance.
I'm sure there's something wrong with the exif data - I just deleted the exif data of some sample pictures and tried to stitch them again - voila - then it works.
I've no idea what happened to the exif data of all my olympus e330 pictures ( I did not touch these pictures for 2 years now )
