Haze Removal
hermer-blr
Haze Removal
by hermer-blr » Fri Oct 14, 2011 12:54 pm
As my configuration is a modest windows 32 bits with 2 GBytes, I need to be very carefull with the way I use APG and play with the memory allocation sliders (in the "parameters" settings).
Is there a way to separately and independently de-haze the images (possibly one by one) and create/edit/etc... the panorama ?
Windows 32 bits - APG
website htt://jmh.trp.free.fr
by AlexandreJ » Fri Oct 14, 2011 12:59 pm
In fact, it's a totally independent task. You can use the dehaze plugin without doing any stitching.
by gkaefer » Fri Oct 14, 2011 2:57 pm
I load my images into a group. I do not use the automatic detection. Using the dehaze plugin will create the dehazed images in the same directory the source files were loaded from and a new group with the dehazed images is automatically created by autopano. In most cases I than close both groups again ans start from scratch loading the dehazed images...
hermer-blr
by hermer-blr » Fri Oct 14, 2011 5:33 pm
It works fine !
I just had to fiddle with the memory allocation setting because I had got some crash of APG. It is now perfect
Many thanks
