how can i remove the tripod from the nadir ?
Aperol
by Aperol » Fri Oct 07, 2011 4:56 pm
hi@all
i know its a noob question, but im learning... is it possible to remove the tripod with autopano pro 2.5 ?
if yes, how?
i must use the tripod... and i must make 360x180 pano
thanks for the support
this is my pano:
Canon 60D / Samyang 8mm fisheye / Sigma 10mm fisheye / NN3 MKII / Manfrotto Xprob055 / Autopano Giga / Panotour Pro
by klausesser » Fri Oct 07, 2011 6:22 pm
Mount your camera at -10° downward-looking and don´t shoot a Nadir. Then you generate an equirectangular image of 360x160°.
After rendering use KRPano´s "Convert Sphere to Cube" droplet and let it make 6 cubefaces. The bottom cubeface you can easily
retouch.
The point is to have e small Nadir-hole which you can close easily.
You can also retouch your Nadir images by erasing/masking some parts. You didn´t tell which lens/camera/head you use - that´s why it´s impossible to give
a serious advice
Aperol
by Aperol » Fri Oct 07, 2011 9:26 pm
hi
thanks for the infos.
i'm using a canon eos 40d , samyang 8mm fisheye , nn3 mkII , manfrotto 055xprob , i made 6 shots around +1 zenit and 1 nadir .
by klausesser » Fri Oct 07, 2011 10:14 pm
Aperol wrote:hi
Ok - thanks. My suggestion keeps the same - apart from the -10° mount.
If you own AutoPanoGiga you also have the KRPano Tools. These contaim several droplets - one of them "convert sphere to cube" is for making 6 cubefaces from the equi.
In the bottom-face retouch the Nadir-hole. Then use the "convert cube to sphere" to make it an equi again.
That´s fast and reliable. It´s more complicated to make and integrate a Nadir shot.
A way to do so: after shooting your sphere, drag the tripod a bit aside, vone the camera/head to look downwards to shoot the point the tripod stood before.
This way you get a plate to integrate into the bottom-shot.
But really: the first way is much faster and more comfortable.
Aperol
by Aperol » Sat Oct 08, 2011 12:29 pm
..... KRPano require a license too...
i just have AutoPano Pro 64bit 2.5.2 , it's possible to fix the image with it?
by klausesser » Sat Oct 08, 2011 1:15 pm
Aperol wrote:..... KRPano require a license too...
Which platform are you on? There are some tools to make cubefaces - i only know them on Macs and they´re not free.
So it would be wise to buy a KRTPano license or to upgrade to AutoPano Giga (which includes KRPano/KRPano Tools)
On PC maybe there are some free tools, i don´t know.
by mediavets » Sat Oct 08, 2011 3:24 pm
klausesser wrote:[Which platform are you on? There are some tools to make cubefaces - i only know them on Macs and they´re not free.
Autopano Giga doesn't include krpano/krpanotools licenses - it is Panotour Pro that includes those licenses.
Pano2QTVR has a free option for Windows:
http://gardengnomesoftware.com/pano2qtvr.php
The more capable Pano2VR is not free but not that expensive either:
http://gardengnomesoftware.com/pano2vr.php
Check out the Patch tool:
http://gardengnomesoftware.com/tutorial.php?movid=09
digipano
by digipano » Sat Oct 08, 2011 6:29 pm
Within autopano we don't have method but here is another method using alpha mask in PS.
http://www.kolor.com/forum/t6821-editing-nadir-shots-without-photoshop?id=6821
