Autopano and Panotools, some questions.
MFranquelo
by MFranquelo » Wed Sep 28, 2011 1:55 pm
Hello all!
Im using Autopano giga 2.6 beta 2 at the moment for the stitching of my panoramas... (i have kolor's panogear also...)
Sometimes i use panotools when autopano does a worse job on control point detection, so my question is the next one...
when exporting from autopano, whats the difference between exporting to .pts , and exporting the template ?
does it keep the autopano's generated control points, in panotools ? and the same RMS ?
what about the rendering, which render engine is better ? or which one do you think is better at control point detection ?
- Also another question, i have a low amount of RAM memory ... 4GB.. how much should i have for a good perfomance in photos of 165 RAW/exposured merged 16bit TIFF images or so... ? im planning to buy more RAM
this week!
- And.. is there much difference between an SDD hard disk for autopano and a normal one ? is it worth to upgrade ?
Thank you!
Regards,Manuel.
by AlexandreJ » Wed Sep 28, 2011 2:16 pm
MFranquelo wrote:Im using Autopano giga 2.6 beta 2 at the moment for the stitching of my panoramas... (i have kolor's panogear also...)
It has nothing in common. PTS is a panotools project whereas the template is something to reapply on another detection
MFranquelo wrote:does it keep the autopano's generated control points, in panotools ? and the same RMS ?
When exported to PTS, it does keep autopano control point.
RMS will be different because lens models are different.
MFranquelo wrote:- Also another question, i have a low amount of RAM memory ... 4GB.. how much should i have for a good perfomance in photos of 165 RAW/exposured merged 16bit TIFF images or so... ? im planning to buy more RAM
this week!
Be sure to have a 64bits OS because if not, you cannot use more RAM.
UK Pano
by UK Pano » Wed Sep 28, 2011 2:25 pm
This post goes into hardware setups etc a lot and may answer some of your questions.
http://www.kolor.com/forum/t12117-should-a-gpu-ram-and-solid-statehdto-speed-up-giga-panorama-process
First to get would be as much RAM as you can afford. This can be relatively cheap and can easily get 16Gb for around GBP100.
MFranquelo
by MFranquelo » Wed Sep 28, 2011 2:39 pm
Thank you for the fast answers! and sorry i should´ve looked in to the hardware forum first!
I also have another question.... im using this camera & lens : Nikon D7000 18-105 mm VR, why does APG tell me on the EXIF data that it has a focal distance of 157mm ?
im also using a focal distance x2duplicator AF-S, so it would be 314mm according to APG,(that is 157x2) ... so i have to "force APG to set the focal distance to 314", is this correct ?
by mediavets » Wed Sep 28, 2011 3:39 pm
MFranquelo wrote:Thank you for the fast answers! and sorry i should´ve looked in to the hardware forum first!
Nikon D7000 has a crop factor of 1.5x.
Yes, I think so.
hermer-blr
by hermer-blr » Wed Sep 28, 2011 5:06 pm
either you "force" or you modify the cameras.txt (or lens.txt) database. It is up to how you feel it depending on your lens usage...
Windows 32 bits - APG
website htt://jmh.trp.free.fr
