Rendering layers and viewing in cs5 problem
Tdub
by Tdub » Wed Jul 20, 2011 5:36 pm
APG: I rendered a couple of test photos, with output as layers, to view in CS5 to see if I need to adjust the lens position to get a better rotation on the entrance pupil. The APG output file is "[Group 1]-DSC00236_DSC00237-2 images". Opening the file in CS5 shows the same in the layers panel, but doesn't allow me to ungroup the layers so I can turn each on and off to see how the images line up. Anyone know how to do this?
Tdub
by Tdub » Wed Jul 20, 2011 6:10 pm
Correction: it appears it did not render the 2 images as a (psb/psd) layered file. (The sources images are jpg.) In the Render panel of APG I select "psb/psd" Format, but it won't let me select "Layers" in the Exported Data section of the Render dialogue. What is required to select Layers?
Tdub
by Tdub » Wed Jul 20, 2011 8:11 pm
Solution: you have to select "Layers" in the Group Settings dialogue, before Detection is done.
Tdub
by Tdub » Wed Jul 20, 2011 9:15 pm
Actually, no solution: It appears the "Layers" option does not work, although you can set it in the main Edit/Preferences dialogue, therafter it is greyed out and you can't select it in the dialogues related to detecting and rending a pano from a set of images.
Lionel Laissus
by Lionel Laissus » Thu Jul 21, 2011 2:12 pm
FYI about layer (Autopano) vs Layer (Photoshop)
http://www.autopano.net/wiki-en/action/view/Autopano_Pro_-_Render#EXPORTED_DATA
I think what you need it's to export all images as Photoshop layers so click in the final render dialogbox EXPORTED DATA /Data/Pictures
Tdub
by Tdub » Thu Jul 21, 2011 7:27 pm
Thank you. That does it.
One more question. When I initially do a Detect in APG of a couple of (test) source images, I get the desired pano layed out in the image window on the right. However, when I later do the detect over again from the same source images, instead of getting a pano layed out, I get the two source images placed directly over each other (see below). What causes this?
Lionel Laissus
by Lionel Laissus » Fri Jul 22, 2011 3:35 pm
issue 806 opened
Could you tell me more information about " However, when I later do the detect over again from the same source images,"
Does it mean you click several times on detect ? Does it failed for good then ?
Are there any ctrl points/links created when it failed ? I saw 1 ctrl point it isn't much :-) !!!!
Tdub
by Tdub » Fri Jul 22, 2011 5:42 pm
I created a test. 3 sets of images. 2 images each. Only about 10% overlap on the two images. When for the first time I bring them into APG, and do a Detect, it nicely finds around 35 control points in the overlap area, and lays out a nice pano on the image screen on the right. Next, I delete everything in APG, start fresh, and (for the second time) load the images into APG, this time it does as above screen shot, finding no control points.
by AlexandreJ » Tue Aug 23, 2011 3:10 pm
Can you share this test case ?
We have a ftp server just for that : http://www.kolor.com/forum/t766-ftp-server
