Joe210 wrote:Hi Asher,
To your second question: you don't have to change the order of the images in the control point editor list. To select the pictures you want to link together, select the first image with the left mouse button and then select the second picture with your left mouse button while holding down the CTRL-key on your keyboard.
Asher Kelman wrote:Hi,
I have two questions about manual stitching in Autopano Giga 2.51 on an Intel 2.66 GHZ Dual Core Xenon Mac running 10.6 and using a mouse with no scroll wheel.
1. I can't get an image to move with the mouse. i don't want to change the yaw, pitch or roll, rather, move an unlinked image to its correct position so as to add control points. Something i'm not seeing, I guess!
2. Also, how does one add control points to non contiguous images in the control point editor list. One can only use the two image boxes for adjacent images in the list, but one can't alter the order of the image list. Is there a keyboard short cut for selecting images which are not in sequence?
Thanks,
Asher
Asher Kelman wrote:Now while we are dealing with making links, where are the instructions for actually choose the exact spots to link as used in PTGui? So far, I can only see how to draw the yellow squares to have Autopano Giga find the points for me. Sometimes, it doesn't pick up what I see clearly matches. Maybe it's part of a smoot metal door, for example.
Asher
mediavets wrote:Asher Kelman wrote:Now while we are dealing with making links, where are the instructions for actually choose the exact spots to link as used in PTGui? So far, I can only see how to draw the yellow squares to have Autopano Giga find the points for me. Sometimes, it doesn't pick up what I see clearly matches. Maybe it's part of a smoot metal door, for example.
Asher
It sounds as if you are familair with PTGui?
If so what is it that you hope APP/APG will offer you that PTGui does not?
as described in the documentation of AutoPano (see here) you can use three different tools: add CP by drawing a rectangle, add them manualy and by using geomtric analysis.
Chris.
klausesser wrote:Hi Asher!
You can move a single image or a group of images by selecting the arrow-symbol in the editor´s upper row AND THEN select the symbol for single images on the left. Very fine: you can move each image or a group of images in real-time with visual control.
mediavets wrote:Asher - do you use a motorised pano head for these high res. panos?
Asher Kelman wrote:I was wondering about the motorized unit sold by Kolor using Papywizard. I use a Mac so I wonder if that is a solution for me.
klausesser wrote:Asher Kelman wrote:I was wondering about the motorized unit sold by Kolor using Papywizard. I use a Mac so I wonder if that is a solution for me.
Hi Asher!
I use a Merlin for several years now - with PapyWizard/Nokia and the T&C hand-controller. There´s definitely no better solution for the money it costs. Both controlling devices write xml files for positioning the shots in APG. That works good - needs some skills nevertheless.
The Merlin including (!) conrolling costs about 500.-€ completey. That´s without any competition. And it works fine! Using the T&C controller speeds up the Merlin and is straighter in using while PapyWizard/Nokia is a bit (!) more versatile.
A matter of taste in the end Both do very fine work - i defiitely prefer it over the Gigapan Epic or the definitely more expensive Epic Pro.
best to you, Klaus
Asher Kelman wrote:What does one gain or lose in each of the control systems and has anyone ported it to the iphone or ipad?
mediavets wrote:Aher,
Where are you based? The reason I ask is that it impacts on costs of various robotic pano heads.
Asher Kelman wrote:Also, BTW, the Panogear version of the Merlin is "out of stock". What's the difference from the regular Merlin?
Asher
Asher
klausesser wrote:Asher Kelman wrote:Hi,
Thanks,
Asher
Hi Asher!
here´s where the symbols are:
