home button
PeterPandi
home button
by PeterPandi » Mon Apr 04, 2011 9:50 pm
hi,
can the home button take viewers to master(first) panorama?
thx
by mediavets » Mon Apr 04, 2011 9:54 pm
PeterPandi wrote:hi,
thx
It doesn't - as you will be aware it re-establishes the default view of the current pano.
PeterPandi
by PeterPandi » Mon Apr 04, 2011 10:11 pm
ok, so how would you go back? apart from thumbnails and hotspot? maybe a home icon(as a logo) in a corner linked to first pano? talking of logos can I place more than one? thx again, today was a breakthrough day!!!
by mediavets » Mon Apr 04, 2011 10:20 pm
PeterPandi wrote:ok, so how would you go back? apart from thumbnails and hotspot?
Or a map.
Or the panoramas list.
Yes that's possible.
Not via the GUI.
PeterPandi
by PeterPandi » Tue Apr 05, 2011 12:12 am
ok. how can i link a map to a pano?
by mediavets » Tue Apr 05, 2011 3:02 am
PeterPandi wrote:ok. how can i link a map to a pano?
The Map feature is to be found in Project properties/Extra.
Select the image you wish to use for the map, the size and location at which to display it and so on
Then you can add hotspots to the map image in the Hotspot editor in a similar manner to adding hotspots to a pano image.
