Registration / upgrade
RickDrew
by RickDrew » Sat Mar 19, 2011 2:31 am
I've looked and can't find the answer. The only link I found leads to a page that's no longer there.
I purchased AutopanoGiga a year or so ago - when it was bundled with the tour. I'm doing to upgrade to the new version, but the information on the tour package is confusing. I use KRpano (Licensed for KRpano and their add-ons - maps, iphone) - do I need to purchase panotour pro? Do I receive it because I have a license for KEpano?
Rick
by mediavets » Sat Mar 19, 2011 5:01 am
If you acquired your APG and krpano licenses before the final release of APP/APG V2.5, on 2 Feb 2011, then you are eligible for a free license key for Panotour Pro.
You'll find all the relevant information here:
http://www.kolor.com/updates.html
Unlike Autopano Tour, Panotour Pro does not require you to have a krpano license to enable any of its features and functions; nor do you need the krpano iphone support license to use the 'mobile compatibility' output capability of Panotour Pro.
