shooting sequence
billjones
shooting sequence
by billjones » Tue Mar 15, 2011 10:22 pm
When shooting a 300+ image pano, what is the preferred shooting order for giga to build the preview. row after row, top to bottom from left to right or column top to bottom - left to right, or the other two choice, or does it make a difference. I am using an epic pro can can shoot in any order desired.
by AlexandreJ » Wed Mar 16, 2011 9:53 am
Autopano Giga doesn't really care. It's the subject that will impose the layout. If you have a lot of fast moving clouds, it would be best to first shoot them and then do the ground ( rows first from top to ground ).
billjones
by billjones » Wed Mar 16, 2011 4:35 pm
It does matter. I shot 300 images from upper right to bottom left, told autopano import there where 12 rows and 25 columns and it layed out the pano backwards and preview was little more then a gray brown screen. When not using the import function it did figure the pano out but couldn't handle the water (ocean) and left those areas black or empty.
As luck would have it, I found autopanos options and they support option 1,3 and 4. I shot using option 2. Live and learn.
by AlexandreJ » Wed Mar 16, 2011 5:15 pm
The option 2 has been added in 2.5.1 RC 1 release.
by mediavets » Wed Mar 16, 2011 6:48 pm
billjones wrote:It does matter. I shot 300 images from upper right to bottom left, told autopano import there where 12 rows and 25 columns and it layed out the pano backwards and preview was little more then a gray brown screen. When not using the import function it did figure the pano out but couldn't handle the water (ocean) and left those areas black or empty.
http://rhmpano.com/gigaepic/order.jpg
As Alexandre says it's in APG 2.5 RC1:
http://www.autopano.net/forum/t11471-autopano-engine-v2.5.1-rc-1
hankkarl
by hankkarl » Thu Mar 17, 2011 4:30 pm
One issue that made me shoot from left to right is that pattern tightens the head on the tripod, if you go the other way, you could loosen it.
And I go left to right, then up and down because my panohead has click stops in the yaw direction, where pitch is an infinity adjustable (ie non-repeatable) setting.
Shoot according to what's best for your panohead.
billjones
by billjones » Thu Mar 17, 2011 5:38 pm
I downloaded the trial and it's 2.5.0
by mediavets » Thu Mar 17, 2011 6:38 pm
billjones wrote:I downloaded the trial and it's 2.5.0
You'll find 2.51 RC1 here:
Autopano Giga - http://download.kolor.com/apg/beta/history
Autopano Pro - http://download.kolor.com/app/beta/history
billjones
by billjones » Fri Mar 18, 2011 1:33 am
Thank you, we'll see what happens.
scobra
by scobra » Tue Mar 22, 2011 7:30 am
Just a thought: option 3, left to right then down, is the only option which does not 'lift' the camera and lens. So it might draw less power, and be easier on your batteries.
by klausesser » Tue Mar 22, 2011 1:47 pm
scobra wrote:. . is the only option which does not 'lift' the camera and lens.
You mean because of earth's gravitational pull and the motor´s power to compensate it when moving the camera up?
When the motor moves the camera down it takes the same amount of power - it as to stop the moving and the weight of camera/lens is the same . . . but of course: gravitation may help :cool:
MIGHT be a fraction of a fraction of mV is saved this way . .
Nice thought anyway . . :)
scobra
by scobra » Wed Mar 23, 2011 12:44 am
I would have thought an electric motor uses more power 'under load' than one which has gravity helping it? I was thinking if you shoot a skyscraper for instance, with options 1 or 2, the camera and lens has to be lifted up every time a new column begins. In option 3, it only has to drop, even though this is a powered servo action, wouldn't it use less battery power? If it uses say 5% less, that 5% might mean the difference between finishing your shoot on the one set of batteries. Of course, with some moving objects, it is not ideal to shoot in rows, so options 3 and 4 would be less than optimal.
by gkaefer » Wed Mar 23, 2011 1:09 pm
:D matrix 1+2 using we could implement a hybrid motor to our merlins which gains energy back when stopping the movement....
by klausesser » Wed Mar 23, 2011 1:27 pm
scobra wrote:I would have thought an electric motor uses more power 'under load' than one which has gravity helping it? I was thinking if you shoot a skyscraper for instance, with options 1 or 2, the camera and lens has to be lifted up every time a new column begins. In option 3, it only has to drop, even though this is a powered servo action, wouldn't it use less battery power? If it uses say 5% less, that 5% might mean the difference between finishing your shoot on the one set of batteries. Of course, with some moving objects, it is not ideal to shoot in rows, so options 3 and 4 would be less than optimal.
Yes - it must have an influence of course. But how relevant it is . . . i doubt 5% difference - as i said before the motor have to stop movement downwards as well as to start movement upwards. So the difference between both amounts of power i guess must be minimal.
I´m sure somebody has measured that already!? :cool:
by klausesser » Wed Mar 23, 2011 1:28 pm
gkaefer wrote::D matrix 1+2 using we could implement a hybrid motor to our merlins which gains energy back when stopping the movement....
Oh yeah! That´s "green thinking" - bravo! :P:cool:
