help with 360 degree pano
hbschwartz
by hbschwartz » Mon Mar 07, 2011 8:48 pm
i just took my first 360 degree pano. when i was in the editor window, all the images were there, but the last three were grayed out and did not render. am i missing a setting? thanks.
by GURL » Mon Mar 07, 2011 9:21 pm
If you click on the Crop tool and then on the Full Sphere: 360 x 180 button, missing images should be rendered ...but that this is necessary is a proof that there is something wrong elsewhere.
- Is there a link between the rightmost image and the leftmost image ?
- Which RMS ?
- Which camera + lens + panohead ?
these are some of the many points one would need for a more useful answer.
hbschwartz
by hbschwartz » Mon Mar 07, 2011 10:08 pm
the rightmost and leftmost images are the same. the rms is around 2.
canon 5d mark II with zeiss 50 mm f2 lens. really right stuff panohead.
hbschwartz
by hbschwartz » Mon Mar 07, 2011 10:22 pm
by the way. if i use photoshop to render my panorama images and stitch them, the panorama comes out correctly.
by Destiny » Mon Mar 07, 2011 10:37 pm
yes... I have done that via the Automate - Photomerge.. in CS5.. It works really great!... BUT.. apg is also great as long as you set it up right. I never have a problem with apg.. I only use Photoshop for stitching images that have not been taken correctly, like incorrect NPP etc... PTGui Pro also does a great job but then you are switching from software apps to software apps.. I think if you take your shots with everything set correctly, then apg is the best way...
D
by mediavets » Mon Mar 07, 2011 11:10 pm
hbschwartz wrote:the rightmost and leftmost images are the same. .
The same? - do you mean identical duplicates?
If so why would you keep both of them in the image set?
Show us a screenshot of the Panorama Editor with this artifact (greyed out images) showing.
hbschwartz
by hbschwartz » Tue Mar 08, 2011 1:15 am
i am a newbie. this is my first 360 degree pano. i thought that i should have the first and last image the same. i guess not??
by gkaefer » Tue Mar 08, 2011 1:41 am
hbschwartz wrote:i am a newbie. this is my first 360 degree pano. i thought that i should have the first and last image the same. i guess not??
no. to much overlap is giving not good results. 20-25% overlap should fit in most cases.
brookehiller@gmail.com
by brookehiller@gmail.com » Fri Mar 18, 2011 11:14 pm
I am a first time user to Autopano Giga and Panatour and having trouble uploading the panoramic images into panotour pro. Do I need to save it as a jpg vs. .pano? And how do I do this?
Best Regards,
Brooke
by mediavets » Fri Mar 18, 2011 11:28 pm
Welcome to the forum...
brookehiller@gmail.com wrote:I am a first time user to Autopano Giga and Panatour and having trouble uploading the panoramic images into panotour pro. Do I need to save it as a jpg vs. .pano? And how do I do this?
You need to render the stitched image to a JPEG or one of the other supported image formats.
The .pano files are project files not image files.
by brookehiller@gmail.com » Fri Mar 18, 2011 11:37 pm
Thank you I was just about to delete my post. I figured that out successfully saved one as a jpeg, but keep getting an error for another saying "invalid bitemap"
Best Regards,
Brooke
by brookehiller@gmail.com » Fri Mar 18, 2011 11:45 pm
One more question for right now... I have a great pan, but the image looks like it has ghosts or a chairs and tables have shadows. I have the smart ghost blend on? Any suggestions?
Best Regards,
Brooke
by mediavets » Sat Mar 19, 2011 12:09 am
brookehiller@gmail.com wrote:Thank you I was just about to delete my post. I figured that out successfully saved one as a jpeg, but keep getting an error for another saying "invalid bitmap"
What operating system are you using and which version of Autopano?
by mediavets » Sat Mar 19, 2011 12:14 am
brookehiller@gmail.com wrote:One more question for right now... I have a great pan, but the image looks like it has ghosts or a chairs and tables have shadows. I have the smart ghost blend on? Any suggestions?
What camera and lens are you using?
Do you use a proper pano head?
Can you show us a screenshot? - use the Post reply rather than the Quick post option and you'll see the option to upload images with your post below the message composition box.
