Force panorama to NOT be 360
komatii
by komatii » Sun Feb 13, 2011 2:58 am
I have a very wide panorama that is not a 360 panorama. It's extremely wide, with each set of images shot from a different location horizontally, rather then a different angle horizontally.
But Autopano always assumes it's a 360 panorama, and tries to connect the left and right sides. Planar projection completely fails [possibly because the panorama is 180 degree pivoted vertically].
It's 180degree vertical, but there is more or less no angular change horizontally, is it even possible to get Autopano to stitch this? There doesn't seem to be a way to tell it to NOT attempt to overlap the left and right sides [there are no control points connecting the images, but it seems to want to put them all on a sphere or cylinder that wraps].
komatii
by GURL » Sun Feb 13, 2011 10:12 am
komatii wrote:Planar projection completely fails [possibly because the panorama is 180 degree pivoted vertically].
This is an unusual situation ! (fisheye or not fisheye?)
Using cylindrical projection and a faked very long focal length (like 1000 mm) comes to mind but then control points next to zenith and nadir would not match!
I would try faked focal length plus manual positioning (used projection would not really matter.) Control points next to the horizon could help (...or not!) BTW, in a first step, an attempt using a small number of source images could help.
With the GPU option, manual positioning of source images works great but this needs a bit of training...
by mediavets » Sun Feb 13, 2011 10:50 am
komatii
Why is it 'pivoted' vertically?
I thought you were talking about shooting in this way - as if walking down a street and taking an image every so many steps - is that correct?
If so APG may be able to stitch it if there is not too much distance between each shooting position and you have a lot of overlap betwen images and you use the Multiple viewpoint option, and define the layout as single row.
What camera and lens did you use and how many images are there in the image set?
by AlexandreJ » Mon Feb 14, 2011 4:59 pm
We never presume 360° for a panorama. It's the content that decides it. Do you most left picture has something in common with the most right picture ?
hankkarl
by hankkarl » Tue Feb 15, 2011 2:36 am
But once APG decides its a 360 (or not a 360), it stays that way. Even if you remove all the bad links.
by AlexandreJ » Tue Feb 15, 2011 9:52 am
Yes, because it already calculated the focal length of each individual images. So even with no links, the focal length has been changed.
hankkarl
by hankkarl » Tue Feb 15, 2011 3:55 pm
We need a way to tell APP to recalculate the focal lenths (perhaps even reset them from the EXIF data). Sometimes a bad link or missing link will cause a big error.
