Better smartblend results
knmiller@me.com
by knmiller@me.com » Wed Jan 05, 2011 9:54 pm
Hi
I am stitching identically exposed images in Autopano and using smartblend but the resulting files have some poor stiched areas seen as lighter and darker patches. I have attached an example below, problem area is bottom left. Does anyone know why this is happening and what I might be able to do to correct this effect.
Thanks in advance.
Kind regards
Kevin
by AlexandreJ » Thu Jan 06, 2011 9:09 am
Did you use color correction in autopano ?
Did you make a pre-processing on image before using them in Autopano ?
knmiller@me.com
by knmiller@me.com » Thu Jan 06, 2011 10:02 pm
Hi Alexandre
I removed the check for Auto Colour correction but to be honest, I have been having the problem with or without this option and on many different files, the above image is just one example.
I fused the bracketed images in photomatix using the same settings, the bracketed sets were also identically shot.
Am I correct to assume that if the blend from Autopano is not perfect then I should tweak this in photoshop using embedd layer masks option.
thanks
Kevin
MJSfoto1956
by MJSfoto1956 » Thu Jan 06, 2011 11:39 pm
The image on the far left looks like it has a different exposure (and thus a different gamma) than the other images. Are you 100% sure that the image brackets were taken in manual mode with no "auto ISO" setting? (recall that auto ISO will change the "exposure")
by mediavets » Thu Jan 06, 2011 11:44 pm
knmiller@me.com wrote:I fused the bracketed images in photomatix using the same settings, the bracketed sets were also identically shot.
thanks
Kevin
Did this scene require bracketed exposures?
bzh360
by bzh360 » Fri Jan 07, 2011 8:44 am
Hi.
With the last 2 release of beta
I'm facing exactly the same issues with color correction in the following cases for a same batch of bkt pictures (5 level):
-bkted pictures managed by apg with raw - exposure fusion
-bkted pictures managed by apg with jpg pre proceced in PS-cs5 with the same tunning option for each level of Bkt
-bkted pictures managed by apg with fused exposure in photomatix.
I'm also turning mad ^^
Toegha Prod. - Createur d'Images Elargies et Rotatives.
http://corryvreckan.fr/test/index.html - Follow us on Facebook
knmiller@me.com
by knmiller@me.com » Fri Jan 07, 2011 1:24 pm
Hi
To answer MJSfoto1956, all image sets were identical in ISO, shutter, aperture etc, i.e. they were shot manually (I never shoot any other way)
To answer mediavets, yes the image does require bracketed images as the shadows were too deep, I was shooting into the light in this scene.
I have done my reading on the various blending options and have experimented with Multiband and Smartblend (including Smartblend settings: minimal pyrimidal and transition smooth) and the result has mostly the same. Therefore, my questions now come down to:-
1) if there is something else that I should be considering to get a better result in Autopano
2) If Autopano can't give the required result, what else can be done outside the application either before or after stitching in Autopano.
Thanks to everyone for their input so far, I feel I am getting closer to the root.
Regards
Kevin
Aeriscera
by Aeriscera » Fri Jan 07, 2011 2:14 pm
Are you saying that you fused the bracketed images before stitching? I don't know about fusion, but tone-mapping before stitching is not the right way to do things - you must stitch each bracket and then tone-map the stitched images.
A
UK Pano
by UK Pano » Fri Jan 07, 2011 2:45 pm
Can you make the source images available for others to experiment with?
by klausesser » Fri Jan 07, 2011 3:09 pm
A
Processing to HDR and tonemapping BEFORE stitching in my eyes definitely is preferable.
But the latest version of APG seems to have a better handling of HDR - i tried it just a bit, because i always do HDR before i stitch.
Using bracketed sets and make them HDR inside APG seems to be kind of "dark sience" . . . :cool:
