Opening Project Failed - Project File Seems Corrupted
GeorgeInvite
by GeorgeInvite » Fri Sep 22, 2017 9:17 pm
I see this message quite a bit. Sometimes straight from trying to open a project from Go Pro Omni importer. Sometimes an existing already open project crashes and when I try to re-open - I get this message.
I am working with very long clips - and the d-warp can take 12 hours. So it's not ideal when the project is corrupted.
Anyone else having this issue? Any quick fix?
MYbar77 likes this post.
DJW
Liked in: 3 posts
Re: Opening Project Failed - Project File Seems Corrupted
by DJW » Mon Sep 25, 2017 9:02 am
Hi George
Personally I've not seen this behaviour, can you repost the error message that you see on screen, its not showing in your initial post...
MYbar77
by MYbar77 » Thu Sep 28, 2017 2:56 pm
I had this happen last night. I too am working with long clips, so I feel your "hours of processing down the drain" pain. I did not take a screen shot of the error message since I was too busy swearing. I did send a crash report, and I do remember that it had auto populated the comment box with something like "bad allocation". When I tried to reopen the kava file, it said it was corrupted. I tried with AV3 and AVP 2.6. Nothing worked.
