Timcode burned in even if it is disabled
net_ralf
by net_ralf » Fri Sep 01, 2017 10:34 am
Hi there,
just came across that little bug (in AVP 3 RC3). I did previews of our omni footage with time codes burned in. I set the tickbox burn into frame. Once I viewed the previews I did adjustments in most of the parts and disabled the time code for final output by switching it into "disabled" without unticking the burn in option. However it still produced the timecode and i was unable to untick it. Workaround was to reset the render settings to default.
Just to let you know
cheers for a great product!
Ralf
