I am trying to output a stitched video as a master in either Pro Res or Cineform
When I export the video the output is scrambled in either of these codecs. I have tried multiple resolutions and both codecs. DWarp has been used. Color harmonization was used. Camera was GoPro Omni at full resolution. H264 exported without issue at 4096x2048 Export is 6000x3000
This is with the GPU encoding enabled with Cuda. When GPU is OpenGL there is no issue and rendering is faster with more GPU usage.
Just thought I would let you know about this issue. Also render log is always blank
