Exception Vertices per edge is not equal to 2 : 1 Error
joshlgibson
Likes: 3 posts
by joshlgibson » Thu Jul 27, 2017 4:23 am
When I try to calculate D.WARP, I'm getting this error message:
Here's the text as well: "Exception Vertices per edge is not equal to 2 : 1 in File: "ParallaxCompensatorTopology.cpp" Line: 419"
I haven't been able to figure out why it's not working. Any ideas?
ClaireM
Liked in: 36 posts
Re: Exception Vertices per edge is not equal to 2 : 1 Error
by ClaireM » Mon Jul 31, 2017 8:45 am
You rig configuration can lead to tricky cases for D.WARP (also according to the way it was stitched).
Stay tuned for RC2 which will provide a quick fix for that.
If with the RC2 version you're still experiencing such an issue, please get back to us.
Best,
Claire
