Dwarp is not working with my gopro rig
Julienbc
by Julienbc » Thu Jul 20, 2017 5:17 pm
Windows 10
GTX 1080 TI
Autopano video 3.0.0
All the gopros (11) are recording in 4K 30. They have a lot of overlap. A little less overlap for the down camera. The rig is genlock.
Here is a screenshot of the problem. It is not a full spherical rig. Will this be fixed in the next update? I cannot buy the upgrade if this doesn't work.
Thanks!
Re: Dwarp is not working with my gopro rig
by Destiny » Thu Jul 20, 2017 11:47 pm
Hi.. I was just thinking that perhaps your issue is related to the fact that you have no video captured above.. I do not really understand how D-Warp really works, but it really looks in many ways and remides me of Vectorised media.. Have you tried D-Warp with a fully captured video arry...? I am happy to test your video my end if you like..
Julienbc
by Julienbc » Fri Jul 21, 2017 1:01 am
I have an other rig that is not fully spherical and it works well.
I don't understand :/
by Destiny » Fri Jul 21, 2017 1:17 am
Oh, well that theory has been blown out of the coffee.. Did you try the other D-Warp options.. Does it work with other video captures using the same rig.. D-Warp is very new so it will be great feedback to the Div team when issues become apparent. Since your video is captured from a distances, it should not have the same parallax issues when captured with close objects, however, the drone parts captured might be confusing it. Using the same rig capturing on the ground at distance, do you have the same issues..
Julienbc
by Julienbc » Fri Jul 21, 2017 4:03 am
Hi Destiny,
Yes I tried the other Dwarp options and they all have the same error. It doesn't even have the time to render, the error message pops right away.
I did not try other footage with the same rig on the ground yet; I am not sure if that's the problem..
Maybe that I can send my original footage the the kolor team and they can fix this?
Thank you for your help! It is very appreciated.
ClaireM
Liked in: 36 posts
by ClaireM » Fri Jul 21, 2017 8:09 am
1. First we're interested in your dataset (videos + kava) to see exactly what is going wrong.
2. In the changelog (you can find it here : http://www.kolor.com/2017/07/18/autopan ... o-3-0-rc1/ ) there is a bug mentionned : Crashes in rigs where there is a too much overlap (3D rigs). Can you try to delete one camera out of two on your 10 horizontal cameras and try it again (if that let you enough overlap to still stitch properly your sequence of course).
Best,
Claire
Julienbc
by Julienbc » Fri Jul 21, 2017 11:11 am
Deleting a camera won't let me enough overlap because I am recording in 16:9 on every gopro which let me record in 4K instead of 2.7k.
where can I send you the footage?
Thank you.
ClaireM
Liked in: 36 posts
by ClaireM » Fri Jul 21, 2017 3:07 pm
Via WeTransfer of whatever solution fits you best.
Just PM the download link. (Those file will remain private of course);
Best,
Claire
Julienbc
by Julienbc » Tue Aug 08, 2017 7:11 pm
Hi Claire, have you received the videos? Even with the new update it is still not working.
Julienbc
by Julienbc » Tue Aug 15, 2017 5:16 pm
up!
