GoPro VR Reframe Plugin gives uggly Black Bars
pzd3mir
by pzd3mir » Tue Jan 24, 2017 1:12 am
In Premiere when I try to edit via GoPro VR Reframe Plugin I select Resolution 3840 X 2160 for the sequence. I put GoPro VR Reframe Plugin on top of the equirectengular clip. Everything works fine untill I select a create elipse mask or create 4-point polygon mask or the free draw bezier tool in the GoPro VR Reframe Tool.
As soon as I press the button I immideately get 2 small black bars top and bottom. Anyone else encountered this?
pzd3mir
Re: GoPro VR Reframe Plugin gives uggly Black Bars
by pzd3mir » Sun Feb 05, 2017 3:49 pm
Also when I use Gopro Reframe and then aplly the mosaic effect on top of that (after Reframe has been applied) I get same black bars. If I make mosaic effect invisible, bars disappear.
JeromeL
by JeromeL » Mon Feb 06, 2017 10:59 am
Have you tried using nested sequences when effects seems incompatible ? Regarding your first post, nesting your sequence with GoPro VR Reframe applied on it and then apply masks (or vice-versa) seems to work fine. You may use that same trick with the mosaic effect.
Let me know if it works for you
Regards
