[APG207-WinXP32] Hangs on Save as template from Panorama Editor
by mediavets » Wed May 19, 2010 6:19 am
APG 2.0.7 hangs when attempting to Save as a template from the Panorama Editor.
picare
by picare » Thu May 20, 2010 10:06 am
I have the same problem!
If you close autopano, the template is saved and works.
Pierre
by AlexandreJ » Thu May 20, 2010 3:41 pm
We tried to reproduce this issue and we couldn't. This function has changed between 2.0.6 and 2.0.7 : the location of template has changed.
Perhaps, there's something wrong with this path ?
changelog wrote:# FIXED - Save as template : did not always work due to writing right. Now the right location is used:
* MAC : /Library/Application Support/Kolor/Autopano Giga/templates
* PC : C:/Users/username/AppData/Local/Kolor/Autopano Giga/templates
* Linux : $HOME/.local/share/data/Kolor/Autopano Giga/templates
by mediavets » Thu May 20, 2010 4:12 pm
AlexandreJ wrote:We tried to reproduce this issue and we couldn't. This function has changed between 2.0.6 and 2.0.7 : the location of template has changed.
Well this is where it is putting the custom template when it hangs:
C:\Documents and Settings\Administrator\Local Settings\Application Data\Kolor\Autopano Giga\templates
Despite hanging it does write the file. But it's hard to end the hung APG task without resorting to the Task Manager.
The location/path you quoted for PC does not appear to exist on my 32-bit Windows XP SP3 PC.
by AlexandreJ » Fri May 21, 2010 8:38 am
I confirm your path on XP ( I quoted the vista path ).
We have reinstalled an XP here and were unable to reproduce it on that config.
The hand is just after hitting the ok button, right ? And the dialog box should close and it doesn't.
picare
by picare » Fri May 21, 2010 10:29 am
I have this problem with a Windows 7 64 bits edition (and app 64 bits!)
I have installed app 32 bits it on a windows xp sp3 32 bits. it works fine.
Regards,
Pierre
by mediavets » Sat May 22, 2010 10:52 am
AlexandreJ wrote:I confirm your path on XP ( I quoted the vista path ).
The hang is just after hitting the ok button, right ? And the dialog box should close and it doesn't.
Yes, that is how it behaves.
