2.07 hangs
Al
2.07 hangs
by Al » Tue May 18, 2010 7:12 pm
I just installed the new version and it hangs (no crash) when making the transition from stitching to rendering in smartblend -- the little blue bar stops in the middle of the 'R'. I uninstalled 2.07 and reinstalled 2.06 and it works fine. I am using a Mac Pro desktop, Snow leopard, and a separate 1 TB scratch disk for APP. If I reinstall 2.07 using the Tiger version it seems to work fine. I also reinstalled the leopard version and allowed it to set all according to APP default settings and it runs fine. When I set an alternative disk for cache, temp files, it hangs at the smartblend render.
enbilaman
by enbilaman » Tue May 18, 2010 8:28 pm
iMac i5-27"/MacOS 10.6.3; 12GB DRAM; 1TB HDD; APP 2.0.7_64-bits
13 images (Canon EOS 5D2 + 17mm fisheye) --> 15880 x 7940 pix. panorama.
Smartblend makes APP to crash right at its start. APP simply quits. This happens both when MacOS is booted on 32-bits and on 64-bits.
Crash reports sent separately via PM.
Michel
photomadnz
by photomadnz » Wed May 19, 2010 9:55 am
Yep hangs going into Smartblend.
spherorama
by spherorama » Wed May 19, 2010 11:37 am
APP works fine on my machine, MacBookPro5,2 Intel Core 2 Duo 2,8 GHz OS 10.6.3. Yesterday I rendered 270 pictures without any problem. But there seems to be an issue with saving Photoshop files. I always get an error message saying "Invalid Bitmap" and then stops without saving anything at the end of smartblend.
Fuji Finepix S2. Fuji Finepix S5, Nikon D700, Pro Nikon D800, Novoflex Panohead VR System Pro, Samyang Fisheye 8mm shaved, Sigma 12-24mm, Nikkor 14-24 1:2,8 G ED, Nikon 35-70mm, Nikon 20 mm 1:2,8
Nikon 180mm 1:2,8, Nikon Macro 60 mm 1:2,8, Zeiss Hasselblad Tele Tessar 8/500 with adapter for Nikon, MK-PanoMachine 5.0 HS, GigaPan Epic Pro
Rico
by Rico » Wed May 19, 2010 1:47 pm
Yes, Invalid bitmap at end of rendering on my MacPro.
by AlexandreJ » Wed May 19, 2010 2:08 pm
we're investigating this issue : 'Invalid Bitmap'
spherorama
by spherorama » Wed May 19, 2010 2:55 pm
Overall feels very good, but then working on the same 270 picture pano while trying to undo some color changes APP crashed out of the blue. See log below:
Process:         AutopanoGiga [1128]
Path:            /Applications/AutopanoGiga-new-07.app/Contents/MacOS/AutopanoGiga
Identifier:      com.kolor.AutopanoGiga
Version:         ??? (207)
Code Type:       X86-64 (Native)
Parent Process:  launchd [122]
Date/Time:       2010-05-19 15:51:27.253 +0200
OS Version:      Mac OS X 10.6.3 (10D573)
Report Version:  6
Interval Since Last Report:          1098302 sec
Crashes Since Last Report:           112
Per-App Interval Since Last Report:  24533 sec
Per-App Crashes Since Last Report:   1
Anonymous UUID:                      1844ED0E-D8C6-43A7-A528-C5C4EF8B2C11
Exception Type:  EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread:  4
Application Specific Information:
*** error for object 0x149452000: entry for pointer being freed from death-row vanished
Thread 0:  Dispatch queue: com.apple.main-thread
0   libSystem.B.dylib                 0x00007fff8748a316 __semwait_signal + 10
1   libSystem.B.dylib                 0x00007fff8748e131 _pthread_cond_wait + 1286
2   QtCore                            0x000000010141aceb QMutexPrivate::wait(int) + 363
3   QtCore                            0x0000000101416fff QMutex::lock() + 351
4   com.kolor.AutopanoGiga            0x000000010003efb8 QVector<HistoryElement>::insert(HistoryElement*, int, HistoryElement const&) + 5960
5   com.kolor.AutopanoGiga            0x000000010028e68c QList<WPanoLayer>::append(WPanoLayer const&) + 20572
6   com.kolor.AutopanoGiga            0x0000000100290385 QList<WPanoLayer>::append(WPanoLayer const&) + 27989
7   QtGui                             0x000000010187002e QWidget::event(QEvent*) + 2318
8   com.kolor.AutopanoGiga            0x00000001002a5a88 QHash<QString, KGLTexItem*>::deleteNode2(QHashData::Node*) + 1112
9   com.kolor.AutopanoGiga            0x00000001002670fb QMap<int, bool>::operator[](int const&) + 10539
10  com.kolor.AutopanoGiga            0x0000000100289bcf QList<WPanoLayer>::append(WPanoLayer const&) + 1439
11  QtGui                             0x000000010181b63d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 189
12  QtGui                             0x00000001018213f4 QApplication::notify(QObject*, QEvent*) + 2036
13  com.kolor.AutopanoGiga            0x0000000100005380 0x100000000 + 21376
14  QtCore                            0x0000000101518acc QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
15  QtGui                             0x000000010181b7c0 qt_sendSpontaneousEvent(QObject*, QEvent*) + 48
16  QtGui                             0x00000001017cc933 -[QCocoaView drawRect:] + 947
17  com.apple.AppKit                  0x00007fff81bd3812 -[NSView _drawRect:clip:] + 3390
18  com.apple.AppKit                  0x00007fff81bd2485 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1325
19  com.apple.AppKit                  0x00007fff81bd0b57 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 767
20  com.apple.AppKit                  0x00007fff81bd1a23 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 4555
21  com.apple.AppKit                  0x00007fff81bd1a23 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 4555
22  com.apple.AppKit                  0x00007fff81bd1a23 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 4555
23  com.apple.AppKit                  0x00007fff81bd0678 -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 254
24  com.apple.AppKit                  0x00007fff81bccf27 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2683
25  com.apple.AppKit                  0x00007fff81b46777 -[NSView displayIfNeeded] + 969
26  com.apple.AppKit                  0x00007fff81b41622 _handleWindowNeedsDisplay + 678
27  com.apple.Foundation              0x00007fff82724a4d __NSFireTimer + 114
28  com.apple.CoreFoundation          0x00007fff813e4708 __CFRunLoopRun + 6488
29  com.apple.CoreFoundation          0x00007fff813e28df CFRunLoopRunSpecific + 575
30  com.apple.HIToolbox               0x00007fff84b1cada RunCurrentEventLoopInMode + 333
31  com.apple.HIToolbox               0x00007fff84b1c83d ReceiveNextEventCommon + 148
32  com.apple.HIToolbox               0x00007fff84b1c798 BlockUntilNextEventMatchingListInMode + 59
33  com.apple.AppKit                  0x00007fff81b16a2a _DPSNextEvent + 708
34  com.apple.AppKit                  0x00007fff81b16379 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
35  com.apple.AppKit                  0x00007fff81adc05b -[NSApplication run] + 395
36  QtGui                             0x00000001017dc175 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1493
37  QtCore                            0x0000000101517be4 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
38  QtCore                            0x0000000101517ef4 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 180
39  QtCore                            0x0000000101519ddc QCoreApplication::exec() + 188
40  com.kolor.AutopanoGiga            0x000000010002012e QDataStream& operator>><QString>(QDataStream&, QList<QString>&) + 7710
41  com.kolor.AutopanoGiga            0x0000000100020294 QDataStream& operator>><QString>(QDataStream&, QList<QString>&) + 8068
42  com.kolor.AutopanoGiga            0x0000000100004ed4 0x100000000 + 20180
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib                 0x00007fff874684ea kevent + 10
1   libSystem.B.dylib                 0x00007fff8746a3bd _dispatch_mgr_invoke + 154
2   libSystem.B.dylib                 0x00007fff8746a094 _dispatch_queue_invoke + 185
3   libSystem.B.dylib                 0x00007fff87469bbe _dispatch_worker_thread2 + 252
4   libSystem.B.dylib                 0x00007fff874694e8 _pthread_wqthread + 353
5   libSystem.B.dylib                 0x00007fff87469385 start_wqthread + 13
Thread 2:
0   libSystem.B.dylib                 0x00007fff87493286 select$DARWIN_EXTSN + 10
1   com.apple.CoreFoundation          0x00007fff81404ef2 __CFSocketManager + 818
2   libSystem.B.dylib                 0x00007fff874888b6 _pthread_start + 331
3   libSystem.B.dylib                 0x00007fff87488769 thread_start + 13
Thread 3:
0   libSystem.B.dylib                 0x00007fff87451376 close$NOCANCEL + 10
1   libSystem.B.dylib                 0x00007fff8749ed7d fclose + 139
2   com.kolor.AutopanoGiga            0x00000001003e1ece mem_mapped_file_impl::~mem_mapped_file_impl() + 79150
3   com.kolor.AutopanoGiga            0x00000001003dd5c1 mem_mapped_file_impl::~mem_mapped_file_impl() + 60449
4   com.kolor.AutopanoGiga            0x00000001003dd662 mem_mapped_file_impl::~mem_mapped_file_impl() + 60610
5   com.kolor.AutopanoGiga            0x0000000100547a55 RAW::Check() + 818183
6   com.kolor.AutopanoGiga            0x0000000100547e29 RAW::Check() + 819163
7   com.kolor.AutopanoGiga            0x00000001005cad90 QMap<QString, QPointer<ImageDef> >::remove(QString const&) + 60432
8   com.kolor.AutopanoGiga            0x00000001005b9a98 QHash<QString, ImageDefCacheItem*>::remove(QString const&) + 5704
9   com.kolor.AutopanoGiga            0x00000001005b9f87 QHash<QString, ImageDefCacheItem*>::remove(QString const&) + 6967
10  com.kolor.AutopanoGiga            0x00000001005b7816 QVector<LensIDProperties::LensDefinition>::free(QVectorTypedData<LensIDProperties::LensDefinition>*) + 5286
11  com.kolor.AutopanoGiga            0x00000001002a2055 QHash<QString, KGLShader20*>::deleteNode2(QHashData::Node*) + 3653
12  com.kolor.AutopanoGiga            0x00000001002a3fc7 QHash<QString, KGLShader20*>::deleteNode2(QHashData::Node*) + 11703
13  QtCore                            0x000000010141b3f5 QThreadPrivate::start(void*) + 165
14  libSystem.B.dylib                 0x00007fff874888b6 _pthread_start + 331
15  libSystem.B.dylib                 0x00007fff87488769 thread_start + 13
Thread 4 Crashed:
0   libSystem.B.dylib                 0x00007fff8751e8c9 usleep$NOCANCEL + 0
1   libSystem.B.dylib                 0x00007fff8753deb8 abort + 93
2   libSystem.B.dylib                 0x00007fff8752cb61 szone_error + 519
3   libSystem.B.dylib                 0x00007fff87498b1c free_large + 1050
4   QtGui                             0x000000010189f5f5 QImageData::~QImageData() + 197
5   QtGui                             0x000000010189f6af QImage::operator=(QImage const&) + 79
6   com.kolor.AutopanoGiga            0x0000000100045721 QVector<HistoryElement>::insert(HistoryElement*, int, HistoryElement const&) + 32433
7   QtCore                            0x000000010141b3f5 QThreadPrivate::start(void*) + 165
8   libSystem.B.dylib                 0x00007fff874888b6 _pthread_start + 331
9   libSystem.B.dylib                 0x00007fff87488769 thread_start + 13
Thread 4 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000115296000  rcx: 0x00007fff8749d886  rdx: 0x0000000000000000
  rdi: 0x0000000000002710  rsi: 0x0000000000000006  rbp: 0x000000011e980900  rsp: 0x000000011e9808e8
   r8: 0x0000000000008867   r9: 0x0000000000000000  r10: 0x00007fff874998ca  r11: 0x0000000000000206
  r12: 0x0000000000000000  r13: 0x0000000149452000  r14: 0x0000000102465000  r15: 0x00000001152960c0
  rip: 0x00007fff8751e8c9  rfl: 0x0000000000010206  cr2: 0x0000000100c37258
Binary Images:
       0x100000000 -        0x1011f7ff7 +com.kolor.AutopanoGiga ??? (207) <A25C8A2D-83D1-E1A5-BA24-7D47ECD59E55> /Applications/AutopanoGiga-new-07.app/Contents/MacOS/AutopanoGiga
       0x1013ab000 -        0x1013e1ffe +QtXml 4.6.2 (compatibility 4.6.0) <4049E68C-B24A-8A34-F9B8-749CE712B9F2> /Applications/AutopanoGiga-new-07.app/Contents/Frameworks/QtXml
       0x1013fc000 -        0x101625fe3 +QtCore 4.6.2 (compatibility 4.6.0) <0299BB23-9F49-0C3E-1892-418F6B41FF35> /Applications/AutopanoGiga-new-07.app/Contents/Frameworks/QtCore
       0x1016c6000 -        0x101766fef +QtOpenGL 4.6.2 (compatibility 4.6.0) <03FE4BDB-8DEC-14C7-15E2-87B85E90EECB> /Applications/AutopanoGiga-new-07.app/Contents/Frameworks/QtOpenGL
       0x1017a5000 -        0x102028fe3 +QtGui 4.6.2 (compatibility 4.6.0) <A84415C5-9CF8-56A7-0286-39987507FC21> /Applications/AutopanoGiga-new-07.app/Contents/Frameworks/QtGui
       0x102303000 -        0x1023f9ff3 +QtNetwork 4.6.2 (compatibility 4.6.0) <F842D3AD-FDE6-C1D7-A89C-68F462CD0537> /Applications/AutopanoGiga-new-07.app/Contents/Frameworks/QtNetwork
       0x102457000 -        0x10245dff7  com.apple.agl 3.0.12 (AGL-3.0.12) <C8CBED46-DB62-3D5C-70BE-B6FD407223A8> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x1027e6000 -        0x1027f2ff3 +libKPanotools_mac.dylib ??? (???) <29479CE2-7B80-669B-15F2-E6126AF594FC> /Applications/AutopanoGiga-new-07.app/Contents/MacOS/plugins/libKPanotools_mac.dylib
       0x1151e2000 -        0x115221ff3 +libKPanoHead_mac.dylib ??? (???) <978CB762-4831-A163-54CE-E79CD6935E22> /Applications/AutopanoGiga-new-07.app/Contents/MacOS/plugins/libKPanoHead_mac.dylib
       0x1153c3000 -        0x1153c7fff  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <4E3DABFF-191F-7E57-2A78-12E34D68FAC4> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
       0x1154f0000 -        0x1155bbfe7  com.apple.audio.units.Components 1.6.1 (1.6.1) <886E356E-03F8-B738-77DF-948346546AA4> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
       0x115657000 -        0x11565dfff  com.apple.audio.AppleHDAHALPlugIn 1.8.4 (1.8.4fc3) <106DABA7-C630-C839-50CE-60D5992E6091> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x118c87000 -        0x118e14fe7  GLEngine ??? (???) <85971DA9-5140-A226-7898-21B2D6C6F7FE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x118e45000 -        0x119267ff7  libclh.dylib 3.1.1 C  (3.1.1) <08830748-80A3-2928-BDC9-D5512BE2715C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
       0x1192bf000 -        0x1192e5fe7  GLRendererFloat ??? (???) <684EBDC4-63B4-BC55-60EF-0F6A7D666551> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x200000000 -        0x2006c3fe7  com.apple.GeForceGLDriver 1.6.10 (6.1.0) <8946B71C-EA96-5AFA-B8B6-E9029EAF56CD> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B633F790-4DDB-53CD-7ACF-2A3682BCEA9F> /usr/lib/dyld
    0x7fff80003000 -     0x7fff80003ff7  com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff80004000 -     0x7fff8003ffff  com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff80040000 -     0x7fff800e0fff  com.apple.LaunchServices 362.1 (362.1) <2740103A-6C71-D99F-8C6F-FA264546AD8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff80215000 -     0x7fff80217fff  libRadiance.dylib ??? (???) <73CE39EA-E38B-4320-8A7D-11C1A08A8A7A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff802a2000 -     0x7fff802b7ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <E83DAF4F-F284-BE0B-3D9D-D573023098B4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff802b8000 -     0x7fff802b9ff7  com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff803fa000 -     0x7fff80c04fe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff80c05000 -     0x7fff80cfdff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <7E4ADB5A-CC77-DCFD-3E54-2F35A2C8D95A> /usr/lib/libiconv.2.dylib
    0x7fff80cfe000 -     0x7fff80d19ff7  com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff80d1a000 -     0x7fff80d78ff7  com.apple.framework.IOKit 2.0 (???) <516EB9AF-4723-FC17-984B-918115E53459> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff80d79000 -     0x7fff80f37fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <1B6C3785-BE99-EAD5-69AB-B28C40466A82> /usr/lib/libicucore.A.dylib
    0x7fff80f38000 -     0x7fff81076fff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff81077000 -     0x7fff81078ff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <D4183AC4-8A65-8368-A9AF-E2A13D18519C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff81079000 -     0x7fff810aafff  libGLImage.dylib ??? (???) <7E8A6ED2-B093-0714-F65A-64ECC41187C4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff81355000 -     0x7fff81358fff  com.apple.help 1.3.1 (41) <54B79BA2-B71B-268E-8752-5C8EE00E49E4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff81359000 -     0x7fff81396ff7  libFontRegistry.dylib ??? (???) <12FDAEB9-01F7-5562-DBC6-7B2374CCAEA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff81397000 -     0x7fff8150cfef  com.apple.CoreFoundation 6.6.1 (550.19) <1051BA2C-DCD7-787C-907C-A50D12AA6049> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff81565000 -     0x7fff81625fe7  libFontParser.dylib ??? (???) <2C6B6ABB-7EF0-3CD8-97D2-9B4534D0056C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff81626000 -     0x7fff816dffff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <5A15E12A-AE8F-1A36-BBC7-564E7D7AD0FB> /usr/lib/libsqlite3.dylib
    0x7fff81721000 -     0x7fff81737fff  com.apple.ImageCapture 6.0 (6.0) <5B5AF8FB-C12A-B51F-94FC-3EC4698E818E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff81738000 -     0x7fff8173bff7  com.apple.securityhi 4.0 (36638) <77F40B57-2D97-7AE5-1331-8945C71DFB57> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff8173c000 -     0x7fff8179efe7  com.apple.datadetectorscore 2.0 (80.7) <F9D2332D-0890-2ED2-1AC8-F85CB89D8BD4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff8179f000 -     0x7fff81ad2fef  com.apple.CoreServices.CarbonCore 861.6 (861.6) <652B1704-460F-F0D1-B917-B08698E0EF7F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff81ad3000 -     0x7fff824c8fe7  com.apple.AppKit 6.6.5 (1038.29) <AC1ED9CC-6149-36EE-AA57-15BA4F05EAAA> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff824c9000 -     0x7fff824f8ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff824f9000 -     0x7fff82543ff7  com.apple.Metadata 10.6.3 (507.8) <A850E5A6-69D8-EBC1-B005-43F72B58EA36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff82544000 -     0x7fff82585fff  com.apple.SystemConfiguration 1.10.2 (1.10.2) <7DADC459-6E38-084A-B333-8332B28C244E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff825b0000 -     0x7fff825bdfe7  libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <540820E4-75E3-B2A0-5EF2-222304250CD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x7fff825be000 -     0x7fff825beff7  com.apple.Carbon 150 (152) <8D8CF535-90BE-691C-EC1B-63FBE2162C9B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff825bf000 -     0x7fff825e5fe7  libJPEG.dylib ??? (???) <85902BC7-43AE-E202-0EEE-3C9996D00971> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff826be000 -     0x7fff8293ffe7  com.apple.Foundation 6.6.2 (751.21) <49BEB8B8-BC1F-B4E4-3D90-A141AC764A8D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff82940000 -     0x7fff82a1aff7  com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff82a1b000 -     0x7fff82b32fef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <EE067D7E-15B3-F043-6FBD-10BA31FE76C7> /usr/lib/libxml2.2.dylib
    0x7fff82bb1000 -     0x7fff82bc3fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
    0x7fff82bff000 -     0x7fff82c4eff7  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <14FD0978-4BE0-336B-A19E-F388694583EB> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
    0x7fff82c4f000 -     0x7fff82c92ff7  libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <677BA546-F215-C5C8-9C65-305E43633FDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff82c93000 -     0x7fff82cc4fef  libTrueTypeScaler.dylib ??? (???) <C15B0761-5136-BD0C-20F7-C8F8A95AF367> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff82da9000 -     0x7fff82e5efe7  com.apple.ColorSync 4.6.3 (4.6.3) <0522B33D-F78A-9A46-1CB2-9073E4F8EFD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff82e61000 -     0x7fff82e77ff7  com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <38D0D705-FD15-38AE-A8B9-F9970508D1BD> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff82e78000 -     0x7fff82eadff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <0C865212-6427-5DE4-40C4-B5739491B691> /usr/lib/libcups.2.dylib
    0x7fff82f1c000 -     0x7fff82f1dfff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x7fff82f37000 -     0x7fff82f8cfef  com.apple.framework.familycontrols 2.0.1 (2010) <E6E1C44A-6513-92DF-F71E-C157C485024C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x7fff82fbc000 -     0x7fff83087fe7  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C85548CF-DED1-4672-0167-3F32A6DD0D55> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x7fff83090000 -     0x7fff83094ff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
    0x7fff83095000 -     0x7fff830abfef  libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
    0x7fff830ac000 -     0x7fff830bdfff  com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x7fff83bb5000 -     0x7fff83bc0ff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff83bf7000 -     0x7fff83f6dfe7  com.apple.RawCamera.bundle 3.0.2 (527) <E70071D3-CC39-4B14-2AA3-EAC42BC84AD4> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff83f6e000 -     0x7fff83fd8fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff83fe2000 -     0x7fff846df037  com.apple.CoreGraphics 1.543.33 (???) <359B3BC6-0152-94D2-3CAA-D8C24C0B9E65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff846e8000 -     0x7fff846e9fff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
    0x7fff846ea000 -     0x7fff8472bfef  com.apple.QD 3.35 (???) <78C9A560-E6F7-DC4F-F85E-E63CF8A98F0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff8472c000 -     0x7fff8472cff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff8472d000 -     0x7fff84731ff7  libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <27FF96BC-1F15-A52D-3339-4BFC49D6810E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff84732000 -     0x7fff8479afff  com.apple.AppleVAFramework 4.8.11 (4.8.11) <14AE8878-A7A6-D024-3DD4-BBFB5E7FC008> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff8479b000 -     0x7fff847aafff  com.apple.NetFS 3.2.1 (3.2.1) <FF21DB1E-F425-1005-FB70-BC19CAF4006E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff847ab000 -     0x7fff84a14ff7  com.apple.QuartzComposer 4.1 (156.13) <0A7E8CDB-77DB-F96F-9CA4-867E9D45EB69> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff84a15000 -     0x7fff84a58fff  libtidy.A.dylib ??? (???) <8AF4DB3A-7BDB-7AF7-0E9C-413BBBD0E380> /usr/lib/libtidy.A.dylib
    0x7fff84aee000 -     0x7fff84decfef  com.apple.HIToolbox 1.6.2 (???) <759E1C39-58EB-C434-3E33-416C04AFE6DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff85014000 -     0x7fff85058ff7  com.apple.ImageCaptureCore 1.0.1 (1.0.1) <788A9BF0-691B-FE10-7385-AF4A7A786478> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff85059000 -     0x7fff8506aff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <C1154E2E-B1CB-1FAD-77ED-B139BA1AB073> /usr/lib/libz.1.dylib
    0x7fff850bb000 -     0x7fff8522bfef  com.apple.MediaToolbox 0.484.5 (484.5) <DA4772AD-9430-024F-39FF-8B9D4B52DCD2> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff8522c000 -     0x7fff852a9fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
    0x7fff852aa000 -     0x7fff852b5ff7  com.apple.HelpData 2.0.4 (34) <B44D2E2A-BC1E-CD63-F8A1-C9465491693A> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff852d2000 -     0x7fff85381fff  edu.mit.Kerberos 6.5.9 (6.5.9) <42364D54-C647-14DE-2B1C-D94DAA03F092> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff85382000 -     0x7fff853c7fff  com.apple.CoreMediaIOServices 130.0 (1035) <6D6834F6-4DB5-03E9-3962-480BBEE176EB> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
    0x7fff853f8000 -     0x7fff8557efe7  com.apple.JavaScriptCore 6531.22 (6531.22.5) <E33572F9-95E3-85D1-5B5E-2B240E3BF2B1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff8557f000 -     0x7fff85598fff  com.apple.CFOpenDirectory 10.6 (10.6) <0F46E102-8B8E-0995-BA85-3D9608F0A30C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff85599000 -     0x7fff8561bfff  com.apple.QuickLookUIFramework 2.2 (327.4) <C35D9F62-73D0-262C-B0CE-BFF64E230588> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff8563b000 -     0x7fff85a7efef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff85a7f000 -     0x7fff85b0bfef  SecurityFoundation 36840.0.0 (compatibility 1.0.0) <B69E2FF9-A698-4923-BC8B-180224B6EF75> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff85c78000 -     0x7fff85c86ff7  libkxld.dylib ??? (???) <E685E658-C908-95B9-8D16-8153C1CE05D7> /usr/lib/system/libkxld.dylib
    0x7fff85c87000 -     0x7fff85ca8fff  libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <1AE68BBB-6536-125C-DE2A-13CA916D0EC4> /usr/lib/libresolv.9.dylib
    0x7fff85ca9000 -     0x7fff85caffff  libCGXCoreImage.A.dylib 543.33.0 (compatibility 64.0.0) <182C8BD9-E1C8-0970-AE82-E9E88F324A5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    0x7fff85cb0000 -     0x7fff85cbfff7  com.apple.opengl 1.6.7 (1.6.7) <63D8F554-2488-4811-EEC7-672FCFAF731B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff85cc0000 -     0x7fff85cc6ff7  IOSurface ??? (???) <F998C45A-CCCF-2306-F37A-389EE0054CB3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff85cc7000 -     0x7fff85ceafff  com.apple.opencl 12.1 (12.1) <AB00CB6B-5BBD-C819-007A-08C0B110AB93> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff85ceb000 -     0x7fff85cebff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff85cfe000 -     0x7fff85d84ff3  com.apple.iLifeMediaBrowser 2.1.5 (368) <BC6090D5-47FD-882D-1123-BA40CB821481> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
    0x7fff85d85000 -     0x7fff85f3ffff  com.apple.ImageIO.framework 3.0.2 (3.0.1) <911FA1A5-7063-6A19-73D3-95B78A265524> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff85f40000 -     0x7fff86026fe7  com.apple.DesktopServices 1.5.5 (1.5.5) <EFCBA7C3-A6CE-9550-FE19-73BB3D046549> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff86027000 -     0x7fff86029fff  com.apple.print.framework.Print 6.1 (237.1) <4513DB2F-737C-B43C-2D0E-23CD6E838014> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8602a000 -     0x7fff8604ffe7  com.apple.CoreVideo 1.6.1 (45.4) <B1516554-88BC-CF1E-5409-BFF27A73D1AF> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff86050000 -     0x7fff8628bfef  com.apple.imageKit 2.0.3 (1.0) <9F7CBDFB-EBDC-5B86-ED43-5195F4AE9D52> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff8628c000 -     0x7fff862d3ff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff862d4000 -     0x7fff86391ff7  com.apple.CoreServices.OSServices 357 (357) <7CFA1963-B639-BE99-12F1-220DF214AB50> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff86392000 -     0x7fff863defff  libauto.dylib ??? (???) <072804DF-36AD-2DBE-7EF8-639CFB79077F> /usr/lib/libauto.dylib
    0x7fff863df000 -     0x7fff863fdfff  libPng.dylib ??? (???) <D0512FBF-911C-A9EC-465D-48A411509D6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff863fe000 -     0x7fff8646afe7  com.apple.CorePDF 1.1 (1.1) <D47B2366-5D1B-147B-B1FA-C9FE36C4EFFF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff8646b000 -     0x7fff8657afe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <826C2437-F760-E049-1719-9C69A3BAA4B0> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff8657b000 -     0x7fff86580ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff866dc000 -     0x7fff86776fff  com.apple.ApplicationServices.ATS 4.2 (???) <E31469D3-A97D-63BB-FB00-05ACB2CEC561> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff86777000 -     0x7fff86881ff7  com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x7fff86882000 -     0x7fff86882ff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff868a4000 -     0x7fff868ecff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff868ed000 -     0x7fff8697cfff  com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff8697d000 -     0x7fff869bffef  com.apple.CoreMedia 0.484.5 (484.5) <FF8F87CB-7087-A46F-D633-6A93054BDBA2> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff869c0000 -     0x7fff86a76fff  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F206BE6D-8777-AE6C-B367-7BEA76C14241> /usr/lib/libobjc.A.dylib
    0x7fff86a77000 -     0x7fff86adffff  com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
    0x7fff86d58000 -     0x7fff86dd6fff  com.apple.CoreText 3.1.0 (???) <B740DA1D-EFD0-CCBF-F893-E3004FE58A98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff86e38000 -     0x7fff86e71ff7  com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
    0x7fff86e72000 -     0x7fff870f7fef  com.apple.security 6.1.1 (37594) <ED08CC62-42E2-E97F-E807-C09EB1CF950D> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff8744e000 -     0x7fff8760dff7  libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <CB9A4929-61AF-DE71-5635-133E9EC95783> /usr/lib/libSystem.B.dylib
    0x7fff87644000 -     0x7fff87644ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff87645000 -     0x7fff8764bff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8764c000 -     0x7fff879e4fe7  com.apple.QuartzCore 1.6.1 (227.18) <ADB9E286-C5AB-3505-35D2-849E1F560A2A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff879e5000 -     0x7fff879eafff  libGIF.dylib ??? (???) <0E58DF99-B3DF-6FF9-E810-CCEC0853C8B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff87a29000 -     0x7fff87a54ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
    0x7fff87a55000 -     0x7fff87a5cfff  com.apple.OpenDirectory 10.6 (10.6) <72A65D76-7831-D31E-F1B3-9E48BF26A98B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff87c41000 -     0x7fff87c55ff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff87c56000 -     0x7fff87c59ff7  libCoreVMClient.dylib ??? (???) <9A0E75A9-7964-CAF9-DEB7-11A073530F64> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff87d4b000 -     0x7fff87ddbfff  com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff87ddc000 -     0x7fff87e5bfff  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <2633DFAC-F6A6-489D-8DF0-F12639CCD8C4> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff87e5c000 -     0x7fff87eadfe7  com.apple.HIServices 1.8.0 (???) <1ABA7802-C1E4-06A0-9035-2792CC915BF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff87eae000 -     0x7fff8801dff7  com.apple.QTKit 7.6.6 (1729) <CEDDAEA5-82F9-FF5D-B9AF-C68ACC1E3225> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff88027000 -     0x7fff880dcfe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff880dd000 -     0x7fff8810dfef  com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff8810e000 -     0x7fff88155fef  com.apple.QuickLookFramework 2.2 (327.4) <4E1658D4-F268-2A82-C095-1D01E9EAD05F> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff88156000 -     0x7fff8815bfff  libGFXShared.dylib ??? (???) <A2C80199-6076-3CBE-E418-E0AD0A3053DE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff88181000 -     0x7fff88181ff7  com.apple.CoreServices 44 (44) <210A4C56-BECB-E3E4-B6EE-7EC53E02265D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff88182000 -     0x7fff8818afff  com.apple.DisplayServicesFW 2.2.2 (251) <3E7C0CF8-117D-9C7F-577C-C199901DFF37> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff8818b000 -     0x7fff881d4fef  libGLU.dylib ??? (???) <FEDE662B-46B2-26D8-3E57-84E4C15A4FB2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff881d5000 -     0x7fff881f5ff7  com.apple.DirectoryService.Framework 3.6 (621.3) <EDCAF7ED-36E1-121F-D294-5CEBC1C34C5A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff88206000 -     0x7fff8822efff  com.apple.DictionaryServices 1.1.1 (1.1.1) <9FD709FC-23F0-F270-EAC1-C590CD516A36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff8822f000 -     0x7fff882fffff  com.apple.CFNetwork 454.9.4 (454.9.4) <33395EDD-D653-6EAD-57A6-9C718D69D2DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff8834a000 -     0x7fff8835efff  libGL.dylib ??? (???) <A85982AB-6395-DE2B-2023-F735093E663D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff8835f000 -     0x7fff88478fef  libGLProgrammability.dylib ??? (???) <9D2B1DA3-C581-73F8-A2E4-01C4CE1C3B32> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff886f2000 -     0x7fff88777fff  com.apple.print.framework.PrintCore 6.2 (312.5) <E736F6DC-2E69-A14D-6BCF-69D14232F8B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff88778000 -     0x7fff88c81fe7  com.apple.VideoToolbox 0.484.5 (484.5) <174EF984-21FE-071C-4AB4-DE345BF87791> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff88c82000 -     0x7fff88c82ff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff88c83000 -     0x7fff88da8fef  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <4DCCD01F-7516-4240-09DC-EE553317D345> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff88da9000 -     0x7fff88df8fef  libTIFF.dylib ??? (???) <D6BED22B-A092-EC70-6E1D-0B52FA6FBBDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <CB9A4929-61AF-DE71-5635-133E9EC95783> /usr/lib/libSystem.B.dylib
Model: MacBookPro5,2, BootROM MBP52.008E.B05, 2 processors, Intel Core 2 Duo, 2.8 GHz, 4 GB, SMC 1.42f4
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.27)
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Serial ATA Device: Hitachi HTS545050B9SA02, 465,76 GB
Serial ATA Device: HL-DT-ST DVDRW  GS21N
USB Device: Globetrotter HSUPA Modem, 0x0af0  (Option NV), 0x7301, 0x26300000
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0x24400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0237, 0x04600000
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8217, 0x06110000
bazaar
by bazaar » Wed May 19, 2010 10:39 pm
sometimes (many times) works for me, but effectively, some times crashes with "invalid bitmap" error message too.
Runs under WinXP64b
Greets,
Xavier
by AlexandreJ » Thu May 20, 2010 9:47 am
Invalid bitmap bug found.
The memory manager did create a bug when using layer in the psd / psb.
Temporary workaround : do not output layer in smartblend mode.
A new release will be made really quickly.
spherorama
by spherorama » Sat May 22, 2010 10:39 pm
After 7:30 hours of render of a gp-pano 29x9 pictures APP crashed:
See log:
Process:         AutopanoGiga [258]
Version:         ??? (207)
Parent Process:  launchd [118]
Date/Time:       2010-05-22 23:31:13.243 +0200
Report Version:  6
Interval Since Last Report:          1193685 sec
Crashes Since Last Report:           121
Per-App Interval Since Last Report:  69093 sec
Per-App Crashes Since Last Report:   3
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: 0x000000000000000a, 0x000000012c210000
Crashed Thread:  3
0   libSystem.B.dylib                 0x00007fff8744f75a mach_msg_trap + 10
1   libSystem.B.dylib                 0x00007fff8744fdcd mach_msg + 59
2   com.apple.CoreFoundation          0x00007fff813e3452 __CFRunLoopRun + 1698
3   com.apple.CoreFoundation          0x00007fff813e28df CFRunLoopRunSpecific + 575
4   com.apple.HIToolbox               0x00007fff84b1cada RunCurrentEventLoopInMode + 333
5   com.apple.HIToolbox               0x00007fff84b1c8df ReceiveNextEventCommon + 310
6   com.apple.HIToolbox               0x00007fff84b1c798 BlockUntilNextEventMatchingListInMode + 59
7   com.apple.AppKit                  0x00007fff81b16a2a _DPSNextEvent + 708
8   com.apple.AppKit                  0x00007fff81b16379 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
9   com.apple.AppKit                  0x00007fff81adc05b -[NSApplication run] + 395
10  QtGui                             0x00000001017dc175 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1493
11  QtCore                            0x0000000101517be4 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
12  QtCore                            0x0000000101517ef4 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 180
13  QtCore                            0x0000000101519ddc QCoreApplication::exec() + 188
14  com.kolor.AutopanoGiga            0x000000010002012e QDataStream& operator>><QString>(QDataStream&, QList<QString>&) + 7710
15  com.kolor.AutopanoGiga            0x0000000100020294 QDataStream& operator>><QString>(QDataStream&, QList<QString>&) + 8068
16  com.kolor.AutopanoGiga            0x0000000100004ed4 0x100000000 + 20180
Thread 2:
2   QtCore                            0x000000010141ae7f thread_sleep(timespec*) + 79
3   QtCore                            0x000000010141afd3 QThread::msleep(unsigned long) + 147
4   com.kolor.AutopanoGiga            0x00000001002a447e QHash<QString, KGLShader20*>::deleteNode2(QHashData::Node*) + 12910
5   QtCore                            0x000000010141b3f5 QThreadPrivate::start(void*) + 165
6   libSystem.B.dylib                 0x00007fff874888b6 _pthread_start + 331
7   libSystem.B.dylib                 0x00007fff87488769 thread_start + 13
Thread 3 Crashed:
0   libSystem.B.dylib                 0x00007fffffe0088b __memcpy + 235
1   com.kolor.AutopanoGiga            0x00000001003bc133 std::vector<boost::intrusive_ptr<i_dib>, std::allocator<boost::intrusive_ptr<i_dib> > >::_M_insert_aux(__gnu_cxx::__normal_iterator<boost::intrusive_ptr<i_dib>*, std::vector<boost::intrusive_ptr<i_dib>, std::allocator<boost::intrusive_ptr<i_dib> > > >, boost::intrusive_ptr<i_dib> const&) + 4067
2   com.kolor.AutopanoGiga            0x00000001003acef9 WLineEditButton::~WLineEditButton() + 81049
3   com.kolor.AutopanoGiga            0x00000001003ae4b2 WLineEditButton::~WLineEditButton() + 86610
4   com.kolor.AutopanoGiga            0x000000010020890d KImage::ClearBitmap() + 22493
5   com.kolor.AutopanoGiga            0x00000001000899cd QVector<PTFile>::append(PTFile const&) + 10077
6   QtCore                            0x000000010141b3f5 QThreadPrivate::start(void*) + 165
7   libSystem.B.dylib                 0x00007fff874888b6 _pthread_start + 331
8   libSystem.B.dylib                 0x00007fff87488769 thread_start + 13
Thread 4:
2   QtCore                            0x000000010141c1a0 QWaitCondition::wait(QMutex*, unsigned long) + 304
3   com.kolor.AutopanoGiga            0x0000000100200d89 KException::KException(std::string const&, std::string const&) + 2169
4   QtCore                            0x000000010141b3f5 QThreadPrivate::start(void*) + 165
5   libSystem.B.dylib                 0x00007fff874888b6 _pthread_start + 331
6   libSystem.B.dylib                 0x00007fff87488769 thread_start + 13
Thread 5:
Thread 6:
Thread 3 crashed with X86 Thread State (64-bit):
  rax: 0x00007fffffe00892  rbx: 0x000000012c4fa560  rcx: 0x000000000000d3b3  rdx: 0x000000000000001c
  rdi: 0x000000012c210000  rsi: 0x000000012c4fe130  rbp: 0x000000012107ebb0  rsp: 0x000000012107ebb0
   r8: 0x00007fffffe0082c   r9: 0x00000001263fc0a4  r10: 0x0000000000000003  r11: 0x000000012c20c430
  r12: 0x000000011f409810  r13: 0x000000011f31d180  r14: 0x000000000000017f  r15: 0x0000000000038a9c
  rip: 0x00007fffffe0088b  rfl: 0x0000000000010202  cr2: 0x000000012c210000
Binary Images:
       0x1027d1000 -        0x1027ddff3 +libKPanotools_mac.dylib ??? (???) <29479CE2-7B80-669B-15F2-E6126AF594FC> /Applications/AutopanoGiga-new-07.app/Contents/MacOS/plugins/libKPanotools_mac.dylib
       0x115289000 -        0x1152c8ff3 +libKPanoHead_mac.dylib ??? (???) <978CB762-4831-A163-54CE-E79CD6935E22> /Applications/AutopanoGiga-new-07.app/Contents/MacOS/plugins/libKPanoHead_mac.dylib
       0x116d72000 -        0x116d98fe7  GLRendererFloat ??? (???) <684EBDC4-63B4-BC55-60EF-0F6A7D666551> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x118ea8000 -        0x119035fe7  GLEngine ??? (???) <85971DA9-5140-A226-7898-21B2D6C6F7FE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x119066000 -        0x119488ff7  libclh.dylib 3.1.1 C  (3.1.1) <08830748-80A3-2928-BDC9-D5512BE2715C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
USB Device: Mass Storage Device, 0x1307, 0x0330, 0x26400000
manderes
by manderes » Thu May 27, 2010 2:40 pm
Same problem here with 2.0.7 and 2.0.8: Mac Pro 16 GB RAM, 10.6.3. Once the image rendered and smartblend starting, APG hangs. Inspecting the Activity Monitor I can see that APG uses a small amout of CPU (about 0%-20% of a total of 800%=8 CPU), so litteraly does nothing. But it eats memory, all the available real memory (about 14 GB) and Virtual Memory is just growing to infinity. This does not only happen with big panos, I tried a small pano, 2 files, 2000x3000 pixels. Same thing.
I tried on my Mac Book (4 GB RAM), same issue.
APG 2.0.7/8 are just not working. I downgraded to 2.0.6.
It's a mess, I think the developpers should take more care and test thoroughly before releasing a new version.
Michael
spherorama
by spherorama » Thu May 27, 2010 3:05 pm
manderes APG 2.0.8. works good on my MacBookPro now. I set the max cache seize to 128 mb. I rendered several panos in the gigapixel range without any problem since the latest fix. Smartblend is a very intense process and it uses all the power it can get. Sometimes it seems the machine hangs, but it is working. When I check back after five minutes or so the progressbar has moved.I had a crash once that was most likely due to the screen saver that activated itself after some time. So i switched it off before I use APG. Now all is fine.
manderes
by manderes » Thu May 27, 2010 4:04 pm
You are right for the Macbook, I didn't try 2.0.8 on it, only 2.0.7. But the problem persists on the MacPro. And with very small panos, 2 files, rendering 2000x3000 pixels only. 2.0.6 takes a couple of seconds to render it, 2.0.7/8 hang after minutes of waiting, just eating memory (more than 20 GB for rendering a 6 MB file). So there must still be a problem in memory management. I understand that Smartblend is a memory glutter, but I compare with 2.0.6 which did a decent job.
Michael
Frank818
by Frank818 » Fri May 28, 2010 5:14 pm
I also have the "hang" issue on a MacPro 8core with 16GB RAM. I am new to this app - where can I get 2.0.6 to see if that works for me?
manderes
by manderes » Sat May 29, 2010 12:55 pm
You can download previous versions at
http://download.autopano.net/history
Scroll down to find the version you need (2.0.6).
by AlexandreJ » Tue Jun 01, 2010 12:27 pm
This hand issue seems to be the activation of the new memory manager that reserve the memory before using smartblend.
We cannot reproduce this case here because we don't such big mac configuration yet.
Are you sure you are running Autopano in 64 bits ? Because if you use the Tiger version on leopard, it will work but in 32 bits mode and with such ram, such behavior can be expected.
manderes
by manderes » Tue Jun 01, 2010 8:03 pm
I'v verified, Autopano Giga 2.0.8 runs in 64-bit mode. I also tried to boot my Mac with 32-bit and 64-bit kernel. There is no difference in behaviour.
I can do some tests for you if you tell me what to do.
Michael
by AlexandreJ » Wed Jun 02, 2010 12:07 pm
We found some issue here in the memory manager for smartblend. With big configurations, this manager may try to allocate chunk that are bigger than 1 G in a single call. It's not really recommended. We'll need to make a new release to fix that. But as we are focused on 2.5 series, it will be postponed after that release.
Frank818
by Frank818 » Sun Jun 20, 2010 1:31 pm
I have now checked out 2.0.9 and it crashes. I'll send the crash log separately.
by AlexandreJ » Mon Jun 21, 2010 4:09 pm
Did you delete the plist from autopano to be sure the default settings are used ( it prevents some issue too ).
Frank818
by Frank818 » Mon Jun 21, 2010 7:56 pm
I have found and trashed two files: $HOME/Library/Preferences/com.kolor.AutopanoGiga.plist and /com.kolor.AutopanoGiga2.plist . That did not resolve the crash. Are there other files that should be removed?
