FYI: 2.0.6 crashes much more often than 2.0.4
MJSfoto1956
by MJSfoto1956 » Tue Dec 22, 2009 8:57 pm
Just an (anectdotal) data point:
My Dell laptop crashes far more often with 2.0.6 than the same laptop did with 2.0.4
Specs:
2Gb, 2 core, Dell D630 (sorry, I'm pretty poor these days)
Typical # of images stitched: 2-30 (max)
Windows XP SP3
Plenty of hard disk space (several hundred gigabytes free)
Observed Behavior: if the size of the individual images is small (e.g. 2800x4000 pixels), and the number of stitched images is also small (e.g. 4-6) then it pretty much works 100% of the time
However, if I have much larger scans (e.g. 4000x6000 pixels) then it almost always dies if I try to do anything -- for example, edit the control points. Note that this behavior will happen with as few as TWO (large) IMAGES!!! Note that this is with only APP running and no other applications.
Other observations: reboot of my laptop sometimes helps, sometimes does not. Resizing the output to be smaller than 9000 pixels sometimes helps, sometimes not. However, in general if the stitched output is greater than 9000 pixels then the occurrence of crashes rises exponentially.
NOTE: I had similar (occasional) problems with 2.0.4 but the frequency of crashes with 2.0.4 is a fraction of what I am currently experiencing with 2.0.6
YMMV
Thanx for listening! (et Joyeux Noel!)
Michael
by GURL » Wed Dec 23, 2009 10:58 am
GPU or not GPU ?
MJSfoto1956
by MJSfoto1956 » Wed Dec 23, 2009 2:55 pm
GURL wrote:GPU or not GPU ?
No GPU.
[bo]
by [bo] » Wed Dec 23, 2009 3:34 pm
Heh, I suppose it's the Smartblend problem again. What blender have you selected in the render settings?
MJSfoto1956
by MJSfoto1956 » Wed Dec 23, 2009 6:39 pm
the problem happens BEFORE any output. For example, when I go to delete control points.
JohnM
by JohnM » Fri Dec 25, 2009 3:10 pm
I also have the feeling that 2.06 is a bit less stable. My copy crashes at different stages, like when removing an image from a layer, or when cropping a large image and sending it to batch stitcher.
phototrek
by phototrek » Sat Dec 26, 2009 3:24 am
Agreed, same here. Reverted back to 2.0.3 and life is much better.
iMac 27"
Canon Equipment
RichG
by RichG » Wed Dec 30, 2009 2:19 pm
How can I get a hold of 2.0.3? I saw the link to download older versions but it's right back to 1.4
Ggigapan Epic 100 / Merlin panohead + Papywizard on Mac OS
Spherical HDR photography for 3d application with Canon 400D
Gigapixel photography with Canon 5d MkII
Stitcher user until Autodesk bought it. Now enjoying Autopano (please don't sellout to AD!) Why are the French so good at panoramic software?
jldallem
by jldallem » Sat Jan 02, 2010 10:05 am
I do agree APP 2.0.4 is more stable than APP 2.0.6.
I installed APP 2.0.4 instead of APP 2.0.6.
by AlexandreJ » Mon Jan 04, 2010 10:05 am
You can get any version here : http://download.autopano.net/history
by klausesser » Mon Jan 04, 2010 11:04 am
MJSfoto1956 wrote:2Gb, 2 core, Dell D630 (sorry, I'm pretty poor these days)
Windows XP SP3
Use an external drive of 250GB min. for swapping!
Using the internal drive maybe the problem with larger stitches.
The OS might use the drive at the same time as APP - that slows
down the process at least or crashes it in the worst case.
(i don´t have any experiences with APP 2 but with APG - and here an external resp. extra internal drive reserved for APG is essential in terms of speed and stability)
RichG
by RichG » Mon Jan 04, 2010 12:15 pm
AlexandreJ wrote:You can get any version here : http://download.autopano.net/history
MJSfoto1956
by MJSfoto1956 » Fri Jan 22, 2010 11:16 pm
Windows XP SP3
Actually, I'm using eSATA drives as my work/swap area. Ironically, things work less "buggy" (but noticeably slower) with the local drive!! Go figure! (I wonder if this is a Windows USB/eSATA driver issue?)
M
