Max pixel resolution
twofun
by twofun » Mon Aug 31, 2009 9:14 pm
hi,
last week we took high quality gigapan in turkey.
and we take almost 1250 photos in 15 megapixel.
and our gigapan pixel 487.000 pixel x 71.250 pixel
but Gigapan max pixel resolution is 300.000 pixel in PSD-PSB mode.
How can we make 487.000 pixel gigapan.
DrSlony
by DrSlony » Mon Aug 31, 2009 9:32 pm
Apapane
by Apapane » Mon Aug 31, 2009 10:27 pm
If you took the panorama with a GigaPan (or other motorized panorama mounts that take individual frames in a grid of rows and columns), you can stitch the frames using the GigaPan stitcher and upload directly to gigapan.org. There is no maximum size when stitched with the GigaPan stitcher, or, as Dr. Slony states, when rendering to the .kro format with AutoPano Giga.
The GigaPan team is working to add direct .kro upload capability to gigapan.org using the GigaPan dedicated uploader.
Richard
twofun
by twofun » Mon Aug 31, 2009 10:35 pm
we are not share our panorama in gigapan.org
we publish in our web site in our system. (360tr.com)
Cause of then we cant use gigapan sticher. Becuase gigapan sticher after align image cant save image. Its directly uploading to gigapan.org
vklaffehn
by vklaffehn » Mon Aug 31, 2009 10:46 pm
The GigaPan stitcher can export the rendered panorama, just choose 'file-export stitched image to', you can save as raw or as tiff, if I remeber right...
Volker
Apapane
by Apapane » Tue Sep 01, 2009 12:12 am
For the size of image described above, the GigaPan stitcher can export to PhotoShop RAW format. You can then do what you wish with the image.
twofun
by twofun » Tue Sep 01, 2009 10:10 am
Ok.
I will try gigapan sticher.
Now Autopano Giga2 stiching image in .kr format.
After 14 hours it will be finish.
Thanks so much for your reply.
[bo]
by [bo] » Tue Sep 01, 2009 10:29 am
That should result in 35 gigapixel panorama? One of the world largest!
by AlexandreJ » Tue Sep 01, 2009 2:52 pm
Something strange :
1250 images * 15 Megapixels = 18 Gigapixels
487.000 pixel x 71.250 pixel = 34 Gigapixels.
You are creating pixels !
I assume you are in rectilinear projection where the 100% slider should be adjusted to get the real figures.
Apapane
by Apapane » Tue Sep 01, 2009 6:54 pm
AlexandreJ wrote:Something strange :
And don't forget to adjust downward due to omage overlap!
