[APP 2.0.1 WinXP noGPU] out of memory error
hankkarl
by hankkarl » Wed May 20, 2009 5:12 pm
Got a Critical Error from APP
Preview Error
Not enough memory
File: *.\\KImage.cpp" Line:111
60 12MP jpgs.
Commit Charge 2805M / 15836M
Free space
C: 39G
D: 145G (Image source files)
F: 140G (APP temp folder)
by AlexandreJ » Thu May 21, 2009 8:41 am
I suppose you are using win XP 64 bits, as well as APP 64 bits ?
hankkarl
by hankkarl » Thu May 21, 2009 5:54 pm
Don't I wish!
WinXP 32bits. APP 32bits.
Lots of RAM (for a 32 bit system). Lots of disk. Not much processor. :(
by AlexandreJ » Fri May 22, 2009 9:48 am
Hum. On the 32 bits version, we limit the possible use of APP to 2 gigas. You cannot access more than that from a single application in fact.
So really reduce the cache size to 100 MB at most. Not more. If you have 8 or 16 cores, put 2 or 4, but not more even if you have them. Cores are also using a lot memory.
bluestar
by bluestar » Fri May 22, 2009 12:01 pm
That raises a question: What exactly is the cache you can set in APP/APG used for? It does not seem to be the maximum amount of RAM used by APP. What happens (benefit/disadwantage) if you set the cache higher?
I think didn't understand the handling of the cache.
Achim
[bo]
by [bo] » Fri May 22, 2009 12:13 pm
I don't think any user really understand the Cache setting, as it has not been thoroughly explained. What I know is that is it used only during rendering, but don't know in which part of it and does it apply if you use Smartblend...
hankkarl
by hankkarl » Fri May 22, 2009 3:04 pm
Reducing the memory worked. Is it just me, or does anyone else remember the cache setting being less than 256K?
