Critical error message after rendering finished. project did not save.
scott
by scott » Wed May 13, 2009 11:14 am
When the rendering was complete a Critical error message appeared saying
.\Ml_graphics\Dib_lib\mem_mngr_win.cpp(253) failed (not enough storage is available to process this command.)
The rended psb file did not save
i've included a picture of what the screen looked like.
the target save folder was on the desktop should i of saved it to my documents.
here is some more info
autopano giga 2
245 images
Size: 211828 x 43271
FOV: 95.63 x 25.40
RMS: 2.64
Lens: Standard
Projection: Planar
Color: LDR
amd 5200 2 cores
2gb ram
xp sp3
nvidia 6100 onboard graphics.
wjh31
by wjh31 » Thu May 14, 2009 1:27 pm
how much space do you have on the disk you are using for the temporary file. For one that big i wouldnt be suprised if you're going to need couple of hundred GB free
edit: also the psb will likely be a couple of dozen GB, so make sure youve enough space on the destination drive aswell
