[APG2 Win XP Pro] Crashes during detection
Aeriscera
by Aeriscera » Sun May 10, 2009 4:35 pm
Hello everyone.
I have set of 179 images that when loaded into APG (in the normal way, not imported) causes APG to crash more-or-less immediately i.e. during detection.
Uploading now (eaves-bug.zip). ETA 8pm, BST
Aeris
Update: The problem seems to be in the last 125 images i.e. from 2726 to the end.
Ronald
by Ronald » Sun May 10, 2009 6:24 pm
I received that error using APG RC1.97 with GPU enabled; with 60 or 80 images... do you have GPU enabled?
Aeriscera
by Aeriscera » Sun May 10, 2009 10:43 pm
I do. I just tried without GPU - same result.
A
by AlexandreJ » Tue May 12, 2009 7:56 am
We checked and it has been fixed.
The issue : 2 files from this set are slightly corrupted ( when clicking on them in the group view you can get an error that tells that ).
Why these two ? We are still checking now.
Aeriscera
by Aeriscera » Tue May 12, 2009 10:37 am
Thanks Alexandre.
Which two images are broken?
Also, I am not sure what you mean by the "group view". Is that the panel on the left of the main APG window?
Aeris
by mediavets » Tue May 12, 2009 10:45 am
Aeriscera wrote:Also, I am not sure what you mean by the "group view". Is that the panel on the left of the main APG window?
Aeris
Yes. You can expand it to the full width of the screen with 4th button from the left at the top.
Then if you double-click on an image it open an image viewer wher you can step through the images.
Aeriscera
by Aeriscera » Tue May 12, 2009 11:15 am
LOL I have only been using APP for 12 months ...
Thanks Andrew.
by AlexandreJ » Tue May 12, 2009 12:41 pm
Yes, use that intergrated viewer and then the left and right arrow to switch to next / previous image : some files will crash at that stage.
