[APG beta 1 Win-7 x64] installed, but wont run on windows 7
digipano
by digipano » Sat Mar 14, 2009 4:23 am
Windows 7 a polished version of Vista is being tested by many,
APG installed fine but does not open at all on it, I tried running in compatibility mode too with admin privileges but did not succeed at all.
Paul
by Paul » Sat Mar 14, 2009 12:13 pm
I installed APG beta1 on Win7 32 in compatibility mode and it runs fine
Paul
digipano
by digipano » Sat Mar 14, 2009 3:49 pm
Paul,
What version are you running of windows 7,
Since there are different build no. there could be some difference among them, or may be its x64 related issue.
I tried vista/xp compatibility mode but none of them let run APG. I will wait for Windows 7 RC1 & hope it will work on it smoothly.
Paul
by Paul » Sat Mar 14, 2009 4:07 pm
Windows7 Ultimate Build 7000
Paul
digipano
by digipano » Sat Mar 28, 2009 3:00 am
Mine is Windows7 Ultimate Build 7000 x64bit
seems its x64 issue, I cant figure out what but it installs fine but wont run at all.
digipano
by digipano » Fri Apr 03, 2009 4:39 am
Any clue to run APG on windows 7 x64?
Compatibility mode does not work for some reason on x64 version.
digipano
by digipano » Sat Apr 04, 2009 5:22 am
Installed APG RC1
It still does not work, even compatibility mode does not work for some reason on x64 version.
Any plans to make it work with windows 7, which is far better than Vista & quite faster too?
by AlexandreJ » Sun Apr 05, 2009 9:23 am
Yes, we'll need to install W7 on a computer to hard check everything. It will not be done for final but after ( we need to concentrate on released OS first :) ).
[bo]
by [bo] » Mon Apr 06, 2009 9:37 am
The current build is 7068 and I *STRONGLY* advise against using older builds (having used 4 of those starting with 6###). APP runs on that build in Vista compatibility mode (set via properties of the exe file).
digipano
by digipano » Mon Apr 06, 2009 3:26 pm
Bo are you confirming about 7068 x64 version?
In 32 bit yes it seems to work but not with x64.
andybryant
by andybryant » Wed May 13, 2009 6:43 am
I'm using Giga on the RC of Win7 build 7100, in x64. It loads and runs fine - and works well for small panos. Any time I get about a hundred pictures of so, it crashes - sometimes on detect, and usually on smartblend.
A.
by AlexandreJ » Wed May 13, 2009 9:57 am
We've checked windows seven support and found a bug ( win32 api still change ). It has been fixed and will be available for next fix release.
[bo]
by [bo] » Wed May 13, 2009 10:00 am
Users browsing this forum: Bing [Bot] and 3 guests
