Jpeg2000 support?
JX
Jpeg2000 support?
by JX » Fri May 04, 2018 3:09 pm
If I select a range of .jp2 images in APG (File/Select images), the program sees nothing. There is literally "0 image" in the file list. Those files have been created with ACDSee Ultimate (developed from raws). The problem is the same if the bit depth is 8 or 16 bits per color.
JX
Re: Jpeg2000 support?
by JX » Mon May 14, 2018 9:26 am
Up! This would be great to be able to have something else available than TIFF files on input when you want to use a 16 bit workflow.
