Overexposed render
pedrom
Overexposed render
by pedrom » Tue Apr 10, 2018 1:10 pm
I've been having an issue with rendering out HDR panoramas. Here is my process:
- import raw images and stack the brackets
- turn off colour correction
- stitch together
- render as Anti-ghost for best blending
When I look at the outputted .hdr image, it's always at maximum exposure. All the exposure information is in the final image as it should be, but It just default 8 - 10 stops too high. Where is the control for this? Is it a bug?
APG 3.7.1 on Linux CentOS 7
Cheers,
Ped
Re: Overexposed render
by Destiny » Tue Apr 10, 2018 2:18 pm
Hi... APG is not so good for HDR...
I suggest you pre-process using Photomatix then use APG to stitch... Best option for your needs....
marzipano
Liked in: 14 posts
by marzipano » Tue Apr 10, 2018 2:28 pm
I agree Photomatix is a better option but from the way you described your process it didn't sound as though you actually invoked APG Fusion at all
You have to click on the Fusion option on the ring menu (2 overlapping squares just right of colour/gamma control) then enable Fusion on the sub screen which appears and then select Exposure Fusion on the Render which should select by default
Apologies of you are already doing all this but it wasn;t obvious from your description !
best
Martin
pedrom
by pedrom » Tue Apr 10, 2018 4:08 pm
marzipano wrote:I agree Photomatix is a better option but from the way you described your process it didn't sound as though you actually invoked APG Fusion at all...
Thanks for the advice on this. However, I am not wanting to modify the HDRI in this way. I am making the image as lighting information for CG application. The bracketing must stay as-shot - Please correct me if I'm wrong, but doesn't Fusion alter the pixels to get an evenly exposed image as the final result?
by Destiny » Tue Apr 10, 2018 10:33 pm
In Photomatix, since you are using your HDR as True HDR for CGI, you will need to enable the correct HDR settings and export as 32bit TIFs or other formats which your software will allow.. In most cases with most workstations, you will not be able to view the images unless you convert to 16bit just to preview.. However, you should still be able to view the images as a 32bit within your CGI software such as Maya or a 3D rendering software etc..
