No integration with Bridge CC 2018   [SOLVED] - View the solution
bgsutton
by bgsutton » Wed Mar 07, 2018 11:52 am
I have just completed a new computer build and have installed many favourite programs including Adobe Bridge CC 2018 and Autopano Giga ver 4.4. In previous installations, I could select a group of images in Bridge and right-click would bring up options, including stitching in APG. This does not occur in the new build. I have to open APG and manually select the images.
Computer: AMD Ryzen Threadripper 1950X, 32GB RAM, Windows 10 Home. I have tried uninstalling and re-installing both programs with no success. Any advice appreciated.
olivierbo
Liked in: 134 posts
Re: No integration with Bridge CC 2018  [SOLVED]
by olivierbo » Wed Mar 07, 2018 2:42 pm
Yes, you're right! I was able to recreate the issue with bridge CC2018. After installing APG, it did not create the Startup Scripts folder.
Unzip the file attached in C:\Users\username\AppData\Roaming\Adobe\Bridge CC 2018
You will get C:\Users\username\AppData\Roaming\Adobe\Bridge CC 2018\Startup Scripts\AutopanoGiga44.brplugin
Then, launch Bridge and enable the plugin.
Thanks for the information. I will investigate that point.
Cheers,
Olivier
Startup Scripts.zip
(172.72 KiB) Downloaded 209 times
bgsutton
by bgsutton » Wed Mar 07, 2018 7:19 pm
Dear Olivier,
Thank you for your prompt reply. I applied your fix and report that it worked perfectly.
Cordialement,
Bruce
olivierbo
Liked in: 134 posts
by olivierbo » Thu Mar 08, 2018 9:41 am
You're very welcome Bruce and sorry for the inconvenience.
Bien cordialement,
Olivier
