Sewing spots in the sky
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Wed Oct 25, 2017 8:58 am
Hello people
I wanted to ask you if the sewing spots in the sky of a Gigapixel panorama are normal? ( to understand me better see attachment). Is that an APG issue or just some settings to change ?? I shoot the pictures with a canon 5d mark III and a roundshot system. I used the default settings of APG!
thanks
Ugo
olivierbo
Liked in: 134 posts
Re: Sewing spots in the sky
by olivierbo » Wed Oct 25, 2017 11:07 am
This is not normal. Have you applied any vignetting/gradient correction and/or click preview icon to apply an automatic color correction and blending?
Best,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Wed Oct 25, 2017 1:29 pm
Hello Olivierbo
I just applied some basic color correction in capture one! no vignetting and no graduated filters !
olivierbo wrote: or click preview icon to apply an automatic color correction and blending?
I do not think...explain me better
thanks
Ugo
olivierbo
Liked in: 134 posts
by olivierbo » Wed Oct 25, 2017 1:36 pm
Hello Ugo,
So please, can you apply a vignetting and/or Gradient correction and click Apply?
The preview icon I mentionned lets you having a good idea of the panorama without applying any correction: http://www.kolor.com/wiki-en/action/vie ... or#Toolbar
Best regards,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Wed Oct 25, 2017 2:56 pm
I've added the changes, but it's still not good! Is that the maximum that APG can manage ?? Are there other ways to create a smooth sky (whiteout photoshop)??
thank
Ugo
olivierbo
Liked in: 134 posts
by olivierbo » Wed Oct 25, 2017 3:01 pm
Hi Ugo,
Is it the rendered pano above or just a preview?
What is the image file format?
Can you try to import your picts using Gigapan import module instead?
Can you try after disabling GPU processing (restart the app to apply the setting)?
Finally, are you able to share/send your footages?
Best,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Wed Oct 25, 2017 4:55 pm
olivierbo wrote: Is it the rendered pano above or just a preview?
It is the rendered pano ! I exported in JPEG and a lot smaller (for sharing)
Sorry I tried Gigapan module but with no results! I can not stich with it :mad:
sorry for my ignorance but what is GPU ??
Yes I can share it ! I just need your email?
olivierbo
Liked in: 134 posts
by olivierbo » Wed Oct 25, 2017 4:57 pm
Hi Ugo,
Thanks for the details. I'll send you an email.
GPU Processing to disable: http://www.kolor.com/wiki-en/action/vie ... _-_General
Best,
Olivier
olivierbo
Liked in: 134 posts
by olivierbo » Fri Oct 27, 2017 12:02 pm
Hello Ugo,
I get the same results but when using Papywizard import module, it seems to be a bit better but not really perfect unfortunately.
Did you make any treatment to the pictures, I mean with Capture one for instance? ;-)
If so, have you tried with the original pictures? Do you have the same issue with all your gigapixel panos?
Best,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Fri Oct 27, 2017 5:12 pm
Hi Oliver
0h I undertand :/
olivierbo wrote:Did you make any treatment to the pictures, I mean with Capture one for instance? ;-)
yes but just some basic workflow: exposure, saturation, levels, clarity, highlights and shadows,defraction. No vignetting and stuff like that. One time I tried to use the tool "Light fall of" that made the borders brighter...but got not good results.
No I never tried with original pictures...I will try ( but I think it has no sense, because the raw pictures need to be processed...).
I had this problem with all gigapixel that I made -> notes that this problem appear just when the sky is really blue and clear.
Thank for your try! I let you know if it works with the non-processed images!
Ugo
olivierbo
Liked in: 134 posts
by olivierbo » Mon Nov 06, 2017 1:52 pm
Thanks Ugo. Wait for your test.
Also, if you can send your RAWs... ;)
Thanks,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Mon Nov 06, 2017 4:17 pm
Hello @olivierbo...I tied and it seems to be a little better..but I am not really satisfied. I need the perfection to be happy ;)
olivierbo
Liked in: 134 posts
by olivierbo » Tue Nov 07, 2017 11:24 am
Yes, I totally agree!
Any chance to get your RAW files? ;)
Best,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Tue Nov 07, 2017 5:41 pm
For me is no problem sharing the raw files...there is a small problem :/ the size is very big...54 GB !!
best
ugo
Screenshot 2017-11-07 17.39.05.jpeg (7.47 KiB) Viewed 6459 times
olivierbo
Liked in: 134 posts
by olivierbo » Wed Nov 08, 2017 9:00 am
Hi Ugo,
Your last example shown above where the results is no yet perfect...is it that big? ;)
Cheers,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Wed Nov 08, 2017 10:31 am
Hi Oliver,
yes the psb file is 22 Gb and the quantity of images is 2032!! Shoot with an 600 mm and a Canon 5D mark 4. Notice that in the attachment above is just a part of the panorama.
best
Ugo
olivierbo
Liked in: 134 posts
by olivierbo » Mon Nov 13, 2017 12:29 pm
Hi Ugo,
Can you try to just correct exposure and color, multiband level -1 and no cutting ?
Cheers,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Mon Nov 13, 2017 1:46 pm
olivierbo wrote:Can you try to just correct exposure and color, multiband level -1 and no cutting ?
Hi Oliver, you mean in APG?? Please explain me better.
best Ugo
olivierbo
Liked in: 134 posts
by olivierbo » Mon Nov 13, 2017 1:49 pm
Yes, in APG edit your panorama, go to Color correction and select Exposure and Color only. Apply. Go to Blend menu, select Multiband/No cutting, level -1 and apply.
Let me know if the result is better or not.
Best,
Olivier
Ugo Visciani
Liked in: 3 posts
by Ugo Visciani » Tue Nov 14, 2017 4:40 pm
Hi oliver...how you can see it does not work...the colors are all crazy
ps. do not look at the stitching is just a quick try
best
Ugo
olivierbo
Liked in: 134 posts
by olivierbo » Wed Nov 15, 2017 2:53 pm
Hi Ugo,
Any chance to have a partial panorama?
Cheers,
Olivier
