Hello, with the new update to Autopano Pro 4.4. the colors are completely washed out and I can not get them to the right level. Bug or do I oversee any new switch ?
Can you add a screenshot of the issue and give further details? Does it work with a previous version and the same images? Any change on your configuration, system,...? What kind of image file format are you using? JPEG, TIFF, DNG, RAW?
I have no possibilities to look at the old version. But this never happend with it before. The only 2 changes that in my system I made is installing the Creators Update of Win 10 and Photoshop CC. Attached are 2 panos. Test1 with automatic white balance. Test 2 with the cam white balance. The other one is the first JPEG of the pano for reference. I am only using JPEGs.
Ok, I found the problem. I changed the color model from sRGB to ProPhoto RGB with the installation of Photoshop CC. Autopanos Preview of the imported images works with ProPhoto RGB. But not the rendering engine ! If I am using only sRGB Jpegs it works fine.
