APG 4.2.3 constantly activating WIFI scanning
mattspace
Likes: 4 posts
by mattspace » Wed Mar 29, 2017 8:55 am
I've noticed whenever I've got a render running with APG 4.2 on MacOSX Yosemite 10.10.5, that system.log in my console is constantly being filled with messages from airportd conducting a scan of local wifi networks.
This is something that is only supposed to happen when opening the airport menulet icon, as far as I know.
When I say constantly, I mean this:
29/03/2017 5:35:48.000 pm kernel[0]: IO80211ScanManager::startScan: Initiating scan.
29/03/2017 5:35:49.000 pm kernel[0]: IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
29/03/2017 5:35:49.000 pm kernel[0]: IO80211ScanManager::startScan: pid 1097 had pending scan request. Deleting.
29/03/2017 5:35:49.000 pm kernel[0]: IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
29/03/2017 5:35:49.000 pm kernel[0]: IO80211ScanManager::startScan: Initiating scan.
29/03/2017 5:35:50.000 pm kernel[0]: IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
29/03/2017 5:35:53.000 pm kernel[0]: IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
29/03/2017 5:35:53.000 pm kernel[0]: IO80211ScanManager::startScan: Initiating scan.
29/03/2017 5:35:53.000 pm kernel[0]: IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
29/03/2017 5:35:54.000 pm kernel[0]: IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
29/03/2017 5:35:54.000 pm kernel[0]: IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
29/03/2017 5:35:54.000 pm kernel[0]: IO80211ScanManager::startScan: Initiating scan.
This will continue without pause as long as APG is conducting the render. Several entries every second for hours on end.
A bit more digging shows the following:
29/03/2017 4:46:54.238 pm airportd[1097]: WARNING: AutopanoGiga (1039) is not entitled for com.apple.wifi.scan, temporarily allowing request with background priority —— all entitlement requirements will be strictly enforced in a future release
Further digging still:
29/03/2017 5:35:18.483 pm airportd[1097]: com.apple.message.domain: com.apple.wifi.internal.scanning
com.apple.message.error: No Error
com.apple.message.duration: 0
com.apple.message.process_name: AutopanoGiga
com.apple.message.mac_address: (my wifi card's MAC address)
SenderMachUUID: C0300690-DDD5-3430-B727-8D5D765814DD
Any idea why this is happening?
mattspace
Likes: 4 posts
Re: APG 4.2 constantly activating WIFI scanning
by mattspace » Wed Mar 29, 2017 9:24 am
wifi.log is also full of references to APG interacting with WIFI
Turning off WIFI whenever I want to render with APG is not a tenable situation.
mattspace
Likes: 4 posts
by mattspace » Wed Mar 29, 2017 11:38 am
Launch APG, get the UI up, and then quit immediately produces more traffic in the wifi.log than this forum can have in a single post...
wifi.log output.
Wed Mar 29 20:31:40.949 IPC: <airportd[1097]> ADDED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:31:40.950 Info: <airportd[1097]> SCAN request received from pid 1688 (AutopanoGiga) with priority 0
Wed Mar 29 20:31:40.951 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:40.951 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:41.304 <kernel> IO80211ScanManager::scanDone: Scheduling cache purge timer in 30 seconds.
Wed Mar 29 20:31:41.304 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:41.304 Driver Event: <airportd[1097]> _bsd_80211_event_callback: SCAN_CACHE_UPDATED (en2)
Wed Mar 29 20:31:41.304 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:41.304     <CWChannel: 0x7f8645c0e630> [channelNumber=1(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.304     <CWChannel: 0x7f8645c42ad0> [channelNumber=2(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.304     <CWChannel: 0x7f8645c426c0> [channelNumber=3(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.304     <CWChannel: 0x7f8645c42ac0> [channelNumber=4(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.304     <CWChannel: 0x7f8645c42ef0> [channelNumber=5(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.304     <CWChannel: 0x7f8645c40b10> [channelNumber=6(2GHz), channelWidth={20MHz}, active]
Wed Mar 29 20:31:41.304 )} took 0.3538 seconds, returned 3 results
Wed Mar 29 20:31:41.305 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:31:41.305 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:41.305 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:41.306 Info: <airportd[1097]> QUERY SCAN CACHE request received from pid 83 (locationd)
Wed Mar 29 20:31:41.737 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:41.737 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:41.737     <CWChannel: 0x7f8645c0d5a0> [channelNumber=7(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.737     <CWChannel: 0x7f8645c0d820> [channelNumber=8(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.737     <CWChannel: 0x7f8645c016a0> [channelNumber=9(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.737     <CWChannel: 0x7f8645c43f20> [channelNumber=10(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.737     <CWChannel: 0x7f8645c44080> [channelNumber=11(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:41.737     <CWChannel: 0x7f8645c444d0> [channelNumber=36(5GHz), channelWidth={40MHz(+1)}, active]
Wed Mar 29 20:31:41.737 )} took 0.4323 seconds, returned 0 results
Wed Mar 29 20:31:41.738 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:41.738 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:42.210 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:42.210 Driver Event: <airportd[1097]> _bsd_80211_event_callback: SCAN_CACHE_UPDATED (en2)
Wed Mar 29 20:31:42.210 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:42.210     <CWChannel: 0x7f8645c448f0> [channelNumber=40(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:31:42.210     <CWChannel: 0x7f8645c44de0> [channelNumber=44(5GHz), channelWidth={40MHz(+1)}, active],
Wed Mar 29 20:31:42.210     <CWChannel: 0x7f8645c47130> [channelNumber=48(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:31:42.210     <CWChannel: 0x7f8645c4ba40> [channelNumber=149(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:42.210     <CWChannel: 0x7f8645c4be60> [channelNumber=153(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:42.210     <CWChannel: 0x7f8645c4c280> [channelNumber=157(5GHz), channelWidth={80MHz}, active]
Wed Mar 29 20:31:42.210 )} took 0.4730 seconds, returned 1 results
Wed Mar 29 20:31:42.211 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:42.211 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:42.212 Info: <airportd[1097]> QUERY SCAN CACHE request received from pid 83 (locationd)
Wed Mar 29 20:31:43.328 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:43.328 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:43.328     <CWChannel: 0x7f8645c4c6a0> [channelNumber=161(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:43.328     <CWChannel: 0x7f8645c4cac0> [channelNumber=165(5GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:43.328     <CWChannel: 0x7f8645c44260> [channelNumber=12(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:31:43.328     <CWChannel: 0x7f8645c44370> [channelNumber=13(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:31:43.328     <CWChannel: 0x7f8645c47550> [channelNumber=52(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:43.328     <CWChannel: 0x7f8645c47a40> [channelNumber=56(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:43.328 )} took 1.1176 seconds, returned 0 results
Wed Mar 29 20:31:43.328 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:31:43.329 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:43.329 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:44.902 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:44.902 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:44.902     <CWChannel: 0x7f8645c47e60> [channelNumber=60(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:44.902     <CWChannel: 0x7f8645c48280> [channelNumber=64(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:44.902     <CWChannel: 0x7f8645c486a0> [channelNumber=100(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:44.902     <CWChannel: 0x7f8645c48ac0> [channelNumber=104(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:44.902     <CWChannel: 0x7f8645c47810> [channelNumber=108(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:44.902     <CWChannel: 0x7f8645c493d0> [channelNumber=112(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:44.902 )} took 1.5737 seconds, returned 0 results
Wed Mar 29 20:31:44.902 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:31:44.903 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:44.903 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:46.305 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:46.305 <kernel> IO80211ScanManager::startScan: pid 1097 had pending scan request. Deleting.
Wed Mar 29 20:31:46.305 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:46.475 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:46.475     <CWChannel: 0x7f8645c497f0> [channelNumber=116(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:46.475     <CWChannel: 0x7f8645c49c10> [channelNumber=120(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:46.475     <CWChannel: 0x7f8645c4a030> [channelNumber=124(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:46.475     <CWChannel: 0x7f8645c4a450> [channelNumber=128(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:46.475     <CWChannel: 0x7f8645c4a870> [channelNumber=132(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:46.475     <CWChannel: 0x7f8645c4ac90> [channelNumber=136(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:46.475 )} took 1.5727 seconds, returned 0 results
Wed Mar 29 20:31:46.475 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:31:46.475 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:31:46.475 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:31:46.998 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:31:46.998 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:46.998     <CWChannel: 0x7f8645c4b0b0> [channelNumber=140(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:46.998     <CWChannel: 0x7f8645c49040> [channelNumber=144(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:46.998 )} took 0.5232 seconds, returned 0 results
Wed Mar 29 20:31:47.047 IPC: <airportd[1097]> INVALIDATED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:31:51.034 IPC: <airportd[1097]> ADDED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:31:51.035 Info: <airportd[1097]> SCAN request received from pid 1688 (AutopanoGiga) with priority 0
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 1 does not require a live scan
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 2 does not require a live scan
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 3 does not require a live scan
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 4 does not require a live scan
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 5 does not require a live scan
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 6 does not require a live scan
Wed Mar 29 20:31:51.035 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:31:51.035 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649320f30> [channelNumber=1(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f864931a220> [channelNumber=2(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f864931af60> [channelNumber=3(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649315040> [channelNumber=4(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f864931db00> [channelNumber=5(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649311590> [channelNumber=6(2GHz), channelWidth={20MHz}, active]
Wed Mar 29 20:31:51.036 )} took 0.0004 seconds, returned 3 results
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 7 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 8 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 9 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 10 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 11 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 36 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:31:51.036 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f86493115d0> [channelNumber=7(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f864931e390> [channelNumber=8(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649317fb0> [channelNumber=9(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f864931a100> [channelNumber=10(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f864931fe20> [channelNumber=11(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649321130> [channelNumber=36(5GHz), channelWidth={40MHz(+1)}, active]
Wed Mar 29 20:31:51.036 )} took 0.0002 seconds, returned 0 results
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 40 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 44 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 48 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 149 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 153 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 157 does not require a live scan
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649322c10> [channelNumber=40(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649323100> [channelNumber=44(5GHz), channelWidth={40MHz(+1)}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649323520> [channelNumber=48(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649327e30> [channelNumber=149(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649328250> [channelNumber=153(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:51.036     <CWChannel: 0x7f8649328670> [channelNumber=157(5GHz), channelWidth={80MHz}, active]
Wed Mar 29 20:31:51.036 )} took 0.0002 seconds, returned 1 results
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 161 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 165 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 12 does not require a live scan
Wed Mar 29 20:31:51.036 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 13 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 52 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 56 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:31:51.037 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649328a90> [channelNumber=161(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649328eb0> [channelNumber=165(5GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f864931ff30> [channelNumber=12(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649321010> [channelNumber=13(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649323940> [channelNumber=52(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649323e30> [channelNumber=56(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.037 )} took 0.0002 seconds, returned 0 results
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 60 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 64 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 100 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 104 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 108 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 112 does not require a live scan
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649324250> [channelNumber=60(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649324670> [channelNumber=64(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649324a90> [channelNumber=100(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649324eb0> [channelNumber=104(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649323c00> [channelNumber=108(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f86493257c0> [channelNumber=112(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 116 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 120 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 124 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 128 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 132 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 136 does not require a live scan
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649325be0> [channelNumber=116(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649326000> [channelNumber=120(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649326420> [channelNumber=124(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649326840> [channelNumber=128(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649326c60> [channelNumber=132(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649327080> [channelNumber=136(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 140 does not require a live scan
Wed Mar 29 20:31:51.037 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 144 does not require a live scan
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f86493274a0> [channelNumber=140(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.037     <CWChannel: 0x7f8649325430> [channelNumber=144(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.037 )} took 0.0001 seconds, returned 0 results
Wed Mar 29 20:31:51.086 IPC: <airportd[1097]> INVALIDATED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:31:51.099 IPC: <airportd[1097]> ADDED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:31:51.100 Info: <airportd[1097]> SCAN request received from pid 1688 (AutopanoGiga) with priority 0
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 1 does not require a live scan
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 2 does not require a live scan
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 3 does not require a live scan
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 4 does not require a live scan
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 5 does not require a live scan
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 6 does not require a live scan
Wed Mar 29 20:31:51.100 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:31:51.100 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:51.100     <CWChannel: 0x7f8645b07dc0> [channelNumber=1(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.100     <CWChannel: 0x7f8645b07fb0> [channelNumber=2(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.100     <CWChannel: 0x7f8645b076d0> [channelNumber=3(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.100     <CWChannel: 0x7f8645b08a40> [channelNumber=4(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.100     <CWChannel: 0x7f8645b08fc0> [channelNumber=5(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.100     <CWChannel: 0x7f8645b09150> [channelNumber=6(2GHz), channelWidth={20MHz}, active]
Wed Mar 29 20:31:51.100 )} took 0.0004 seconds, returned 3 results
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 7 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 8 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 9 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 10 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 11 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 36 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:31:51.101 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b09290> [channelNumber=7(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b09440> [channelNumber=8(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b09570> [channelNumber=9(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b096d0> [channelNumber=10(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b09830> [channelNumber=11(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b09c80> [channelNumber=36(5GHz), channelWidth={40MHz(+1)}, active]
Wed Mar 29 20:31:51.101 )} took 0.0002 seconds, returned 0 results
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 40 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 44 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 48 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 149 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 153 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 157 does not require a live scan
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b0a0a0> [channelNumber=40(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b0a590> [channelNumber=44(5GHz), channelWidth={40MHz(+1)}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b0a9b0> [channelNumber=48(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b0e590> [channelNumber=149(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b0e9b0> [channelNumber=153(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:51.101     <CWChannel: 0x7f8645b0edd0> [channelNumber=157(5GHz), channelWidth={80MHz}, active]
Wed Mar 29 20:31:51.101 )} took 0.0002 seconds, returned 1 results
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 161 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 165 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 12 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 13 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 52 does not require a live scan
Wed Mar 29 20:31:51.101 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 56 does not require a live scan
Wed Mar 29 20:31:51.102 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0f1f0> [channelNumber=161(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0f610> [channelNumber=165(5GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b09a10> [channelNumber=12(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b09b20> [channelNumber=13(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0add0> [channelNumber=52(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0b2c0> [channelNumber=56(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.102 )} took 0.0002 seconds, returned 0 results
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 60 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 64 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 100 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 104 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 108 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 112 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0b6e0> [channelNumber=60(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0bb00> [channelNumber=64(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0bf20> [channelNumber=100(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b06a00> [channelNumber=104(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0b090> [channelNumber=108(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b04ee0> [channelNumber=112(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 116 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 120 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 124 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 128 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 132 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 136 does not require a live scan
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0c340> [channelNumber=116(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0c760> [channelNumber=120(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0cb80> [channelNumber=124(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0cfa0> [channelNumber=128(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0d3c0> [channelNumber=132(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0d7e0> [channelNumber=136(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 140 does not require a live scan
Wed Mar 29 20:31:51.102 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 144 does not require a live scan
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b0dc00> [channelNumber=140(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:31:51.102     <CWChannel: 0x7f8645b04b50> [channelNumber=144(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:31:51.102 )} took 0.0001 seconds, returned 0 results
Wed Mar 29 20:31:51.151 IPC: <airportd[1097]> INVALIDATED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:01.020 IPC: <airportd[1097]> ADDED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:01.021 Info: <airportd[1097]> SCAN request received from pid 1688 (AutopanoGiga) with priority 0
Wed Mar 29 20:32:01.022 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:01.022 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:01.233 Driver Event: <airportd[1097]> _bsd_80211_event_callback: SCAN_CACHE_UPDATED (en2)
Wed Mar 29 20:32:01.233 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:01.234 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:01.234     <CWChannel: 0x7f8649509f60> [channelNumber=1(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.234     <CWChannel: 0x7f8649501980> [channelNumber=2(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.234     <CWChannel: 0x7f8649509960> [channelNumber=3(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.234     <CWChannel: 0x7f8649501970> [channelNumber=4(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.234     <CWChannel: 0x7f864952c8b0> [channelNumber=5(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.234     <CWChannel: 0x7f864952c1a0> [channelNumber=6(2GHz), channelWidth={20MHz}, active]
Wed Mar 29 20:32:01.234 )} took 0.2120 seconds, returned 3 results
Wed Mar 29 20:32:01.234 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:01.234 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:01.235 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:01.235 Info: <airportd[1097]> QUERY SCAN CACHE request received from pid 83 (locationd)
Wed Mar 29 20:32:01.663 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:01.663 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:01.663     <CWChannel: 0x7f864952f7a0> [channelNumber=7(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.663     <CWChannel: 0x7f8649523460> [channelNumber=8(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.663     <CWChannel: 0x7f8649511660> [channelNumber=9(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.663     <CWChannel: 0x7f864952ea40> [channelNumber=10(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.663     <CWChannel: 0x7f8649517860> [channelNumber=11(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:01.663     <CWChannel: 0x7f8649509240> [channelNumber=36(5GHz), channelWidth={40MHz(+1)}, active]
Wed Mar 29 20:32:01.663 )} took 0.4291 seconds, returned 0 results
Wed Mar 29 20:32:01.664 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:01.664 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:02.134 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:02.134 Driver Event: <airportd[1097]> _bsd_80211_event_callback: SCAN_CACHE_UPDATED (en2)
Wed Mar 29 20:32:02.134 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:02.134     <CWChannel: 0x7f8649515360> [channelNumber=40(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:32:02.134     <CWChannel: 0x7f8649513490> [channelNumber=44(5GHz), channelWidth={40MHz(+1)}, active],
Wed Mar 29 20:32:02.134     <CWChannel: 0x7f864952b7a0> [channelNumber=48(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:32:02.134     <CWChannel: 0x7f8649529dd0> [channelNumber=149(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:02.134     <CWChannel: 0x7f864951a920> [channelNumber=153(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:02.134     <CWChannel: 0x7f8649512920> [channelNumber=157(5GHz), channelWidth={80MHz}, active]
Wed Mar 29 20:32:02.134 )} took 0.4709 seconds, returned 1 results
mattspace
Likes: 4 posts
by mattspace » Wed Mar 29, 2017 11:39 am
continuing...
Wed Mar 29 20:32:02.135 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:02.135 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:02.136 Info: <airportd[1097]> QUERY SCAN CACHE request received from pid 83 (locationd)
Wed Mar 29 20:32:03.253 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:03.253 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:03.253     <CWChannel: 0x7f864951a640> [channelNumber=161(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:03.253     <CWChannel: 0x7f8649529ac0> [channelNumber=165(5GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:03.253     <CWChannel: 0x7f8649507380> [channelNumber=12(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:32:03.253     <CWChannel: 0x7f8649509b40> [channelNumber=13(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:32:03.253     <CWChannel: 0x7f8649521d20> [channelNumber=52(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:03.253     <CWChannel: 0x7f8649526d50> [channelNumber=56(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:03.253 )} took 1.1185 seconds, returned 0 results
Wed Mar 29 20:32:03.253 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:03.254 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:03.254 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:04.826 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:04.826 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:04.826     <CWChannel: 0x7f8649528f10> [channelNumber=60(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:04.826     <CWChannel: 0x7f864952ed40> [channelNumber=64(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:04.826     <CWChannel: 0x7f8649517580> [channelNumber=100(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:04.826     <CWChannel: 0x7f86495202a0> [channelNumber=104(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:04.826     <CWChannel: 0x7f8649521410> [channelNumber=108(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:04.826     <CWChannel: 0x7f86495117f0> [channelNumber=112(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:04.826 )} took 1.5728 seconds, returned 0 results
Wed Mar 29 20:32:04.826 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:04.827 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:04.827 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:06.234 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:06.234 <kernel> IO80211ScanManager::startScan: pid 1097 had pending scan request. Deleting.
Wed Mar 29 20:32:06.234 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:06.398 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:06.398     <CWChannel: 0x7f8649522fc0> [channelNumber=116(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.398     <CWChannel: 0x7f864952c010> [channelNumber=120(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:06.398     <CWChannel: 0x7f86495290b0> [channelNumber=124(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.398     <CWChannel: 0x7f8649524930> [channelNumber=128(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:06.398     <CWChannel: 0x7f864951a370> [channelNumber=132(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.398     <CWChannel: 0x7f864951cf00> [channelNumber=136(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:06.398 )} took 1.5721 seconds, returned 0 results
Wed Mar 29 20:32:06.398 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:06.399 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:06.399 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:06.923 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:06.923 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:06.923     <CWChannel: 0x7f864952aed0> [channelNumber=140(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.923     <CWChannel: 0x7f8649520c00> [channelNumber=144(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:06.923 )} took 0.5247 seconds, returned 0 results
Wed Mar 29 20:32:06.972 IPC: <airportd[1097]> INVALIDATED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:06.985 IPC: <airportd[1097]> ADDED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:06.986 Info: <airportd[1097]> SCAN request received from pid 1688 (AutopanoGiga) with priority 0
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 1 does not require a live scan
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 2 does not require a live scan
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 3 does not require a live scan
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 4 does not require a live scan
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 5 does not require a live scan
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 6 does not require a live scan
Wed Mar 29 20:32:06.986 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:32:06.987 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649509330> [channelNumber=1(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649518c20> [channelNumber=2(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f86495270e0> [channelNumber=3(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649501240> [channelNumber=4(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649500500> [channelNumber=5(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649501ad0> [channelNumber=6(2GHz), channelWidth={20MHz}, active]
Wed Mar 29 20:32:06.987 )} took 0.0004 seconds, returned 3 results
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 7 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 8 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 9 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 10 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 11 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 36 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649509740> [channelNumber=7(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649509750> [channelNumber=8(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f86495057a0> [channelNumber=9(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649504eb0> [channelNumber=10(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649504ec0> [channelNumber=11(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649504bd0> [channelNumber=36(5GHz), channelWidth={40MHz(+1)}, active]
Wed Mar 29 20:32:06.987 )} took 0.0002 seconds, returned 0 results
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 40 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 44 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 48 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 149 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 153 does not require a live scan
Wed Mar 29 20:32:06.987 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 157 does not require a live scan
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649511920> [channelNumber=40(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649529ef0> [channelNumber=44(5GHz), channelWidth={40MHz(+1)}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649529b60> [channelNumber=48(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f864951e740> [channelNumber=149(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f8649515a20> [channelNumber=153(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:06.987     <CWChannel: 0x7f864952b800> [channelNumber=157(5GHz), channelWidth={80MHz}, active]
Wed Mar 29 20:32:06.987 )} took 0.0003 seconds, returned 1 results
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 161 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 165 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 12 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 13 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 52 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 56 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:32:06.988 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649521d60> [channelNumber=161(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649523b60> [channelNumber=165(5GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649501970> [channelNumber=12(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649501980> [channelNumber=13(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f864952c4c0> [channelNumber=52(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649507350> [channelNumber=56(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:06.988 )} took 0.0002 seconds, returned 0 results
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 60 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 64 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 100 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 104 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 108 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 112 does not require a live scan
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f864951bba0> [channelNumber=60(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649520580> [channelNumber=64(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649523ea0> [channelNumber=100(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f864951ae20> [channelNumber=104(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f864951ea90> [channelNumber=108(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649526010> [channelNumber=112(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 116 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 120 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 124 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 128 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 132 does not require a live scan
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 136 does not require a live scan
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649522020> [channelNumber=116(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649528500> [channelNumber=120(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649510c90> [channelNumber=124(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f864952ced0> [channelNumber=128(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f864952fdd0> [channelNumber=132(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.988     <CWChannel: 0x7f8649526360> [channelNumber=136(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:06.988 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 140 does not require a live scan
Wed Mar 29 20:32:06.989 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga on channel 144 does not require a live scan
Wed Mar 29 20:32:06.989 Scan: <airportd[1097]> Cache-assisted scan request for AutopanoGiga does not require a live scan
Wed Mar 29 20:32:06.989 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:06.989     <CWChannel: 0x7f864951fb30> [channelNumber=140(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:06.989     <CWChannel: 0x7f8649507410> [channelNumber=144(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:06.989 )} took 0.0001 seconds, returned 0 results
Wed Mar 29 20:32:07.039 IPC: <airportd[1097]> INVALIDATED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:11.306 <kernel> IO80211ScanManager::cachePurge: clearEntries[0] Firing!
Wed Mar 29 20:32:11.306 <kernel> IO80211ScanManager::cachePurge: Rescheduling in 20 seconds.
Wed Mar 29 20:32:17.032 IPC: <airportd[1097]> ADDED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:17.032 Info: <airportd[1097]> SCAN request received from pid 1688 (AutopanoGiga) with priority 0
Wed Mar 29 20:32:17.033 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:17.034 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:17.464 Driver Event: <airportd[1097]> _bsd_80211_event_callback: SCAN_CACHE_UPDATED (en2)
Wed Mar 29 20:32:17.464 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:17.464 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:17.464     <CWChannel: 0x7f8649001640> [channelNumber=1(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.464     <CWChannel: 0x7f8649002cc0> [channelNumber=2(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.464     <CWChannel: 0x7f8649002010> [channelNumber=3(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.464     <CWChannel: 0x7f8649002510> [channelNumber=4(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.464     <CWChannel: 0x7f8649002db0> [channelNumber=5(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.464     <CWChannel: 0x7f8649002f40> [channelNumber=6(2GHz), channelWidth={20MHz}, active]
Wed Mar 29 20:32:17.464 )} took 0.4315 seconds, returned 3 results
Wed Mar 29 20:32:17.465 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:17.465 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:17.465 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:17.466 Info: <airportd[1097]> QUERY SCAN CACHE request received from pid 83 (locationd)
Wed Mar 29 20:32:17.843 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:17.843 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:17.843     <CWChannel: 0x7f8649003080> [channelNumber=7(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.843     <CWChannel: 0x7f8649003230> [channelNumber=8(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.843     <CWChannel: 0x7f8649003360> [channelNumber=9(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.843     <CWChannel: 0x7f86490034c0> [channelNumber=10(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.843     <CWChannel: 0x7f8649003620> [channelNumber=11(2GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:17.843     <CWChannel: 0x7f8649003a70> [channelNumber=36(5GHz), channelWidth={40MHz(+1)}, active]
Wed Mar 29 20:32:17.843 )} took 0.3787 seconds, returned 0 results
Wed Mar 29 20:32:17.844 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:17.844 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:18.053 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:18.053 Driver Event: <airportd[1097]> _bsd_80211_event_callback: SCAN_CACHE_UPDATED (en2)
Wed Mar 29 20:32:18.053 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:18.053     <CWChannel: 0x7f8649004510> [channelNumber=40(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:32:18.053     <CWChannel: 0x7f8649004a00> [channelNumber=44(5GHz), channelWidth={40MHz(+1)}, active],
Wed Mar 29 20:32:18.053     <CWChannel: 0x7f8649004e20> [channelNumber=48(5GHz), channelWidth={40MHz(-1)}, active],
Wed Mar 29 20:32:18.053     <CWChannel: 0x7f86490091f0> [channelNumber=149(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:18.053     <CWChannel: 0x7f8649009610> [channelNumber=153(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:18.053     <CWChannel: 0x7f8649009a30> [channelNumber=157(5GHz), channelWidth={80MHz}, active]
Wed Mar 29 20:32:18.053 )} took 0.2098 seconds, returned 1 results
Wed Mar 29 20:32:18.054 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:18.054 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:18.055 Info: <airportd[1097]> QUERY SCAN CACHE request received from pid 83 (locationd)
Wed Mar 29 20:32:19.142 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:19.142 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:19.143     <CWChannel: 0x7f8649009e50> [channelNumber=161(5GHz), channelWidth={80MHz}, active],
Wed Mar 29 20:32:19.143     <CWChannel: 0x7f864900a270> [channelNumber=165(5GHz), channelWidth={20MHz}, active],
Wed Mar 29 20:32:19.143     <CWChannel: 0x7f8649003800> [channelNumber=12(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:32:19.143     <CWChannel: 0x7f8649003910> [channelNumber=13(2GHz), channelWidth={20MHz}],
Wed Mar 29 20:32:19.143     <CWChannel: 0x7f8649005240> [channelNumber=52(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:19.143     <CWChannel: 0x7f8649005730> [channelNumber=56(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:19.143 )} took 1.0890 seconds, returned 0 results
Wed Mar 29 20:32:19.143 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:19.143 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:19.143 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:20.716 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:20.716 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:20.716     <CWChannel: 0x7f8649005b50> [channelNumber=60(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:20.716     <CWChannel: 0x7f8649005f70> [channelNumber=64(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:20.716     <CWChannel: 0x7f8649006390> [channelNumber=100(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:20.716     <CWChannel: 0x7f86490067b0> [channelNumber=104(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:20.716     <CWChannel: 0x7f8649005500> [channelNumber=108(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:20.716     <CWChannel: 0x7f86490070c0> [channelNumber=112(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:20.716 )} took 1.5735 seconds, returned 0 results
Wed Mar 29 20:32:20.716 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:20.717 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:20.717 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:22.288 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:22.289 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:22.289     <CWChannel: 0x7f86490074e0> [channelNumber=116(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:22.289     <CWChannel: 0x7f8649007900> [channelNumber=120(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:22.289     <CWChannel: 0x7f8649003d40> [channelNumber=124(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:22.289     <CWChannel: 0x7f8649007c00> [channelNumber=128(5GHz), channelWidth={40MHz(-1)}, DFS],
Wed Mar 29 20:32:22.289     <CWChannel: 0x7f8649008020> [channelNumber=132(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:22.289     <CWChannel: 0x7f8649008440> [channelNumber=136(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:22.289 )} took 1.5721 seconds, returned 0 results
Wed Mar 29 20:32:22.289 Info: <Wi-Fi Menu Extra[325]> scan cache updated
Wed Mar 29 20:32:22.289 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:22.289 <kernel> IO80211ScanManager::startScan: Initiating scan.
Wed Mar 29 20:32:22.464 <kernel> IO80211ScanManager::startScan: Broadcast scan request received from 'airportd' (pid 1097) ().
Wed Mar 29 20:32:22.464 <kernel> IO80211ScanManager::startScan: pid 1097 had pending scan request. Deleting.
Wed Mar 29 20:32:22.465 <kernel> IO80211ScanManager::getScanResult: All scan results returned for 'airportd' (pid 1097).
Wed Mar 29 20:32:22.811 AutoJoin: <airportd[1097]> Successful cache-assisted scan request for AutopanoGiga with channels {(
Wed Mar 29 20:32:22.812     <CWChannel: 0x7f8649008860> [channelNumber=140(5GHz), channelWidth={40MHz(+1)}, DFS],
Wed Mar 29 20:32:22.812     <CWChannel: 0x7f8649006d30> [channelNumber=144(5GHz), channelWidth={40MHz(-1)}, DFS]
Wed Mar 29 20:32:22.812 )} took 0.5228 seconds, returned 0 results
Wed Mar 29 20:32:22.862 IPC: <airportd[1097]> INVALIDATED XPC CLIENT CONNECTION [AutopanoGiga (pid=1688, euid=502, egid=20)]
Wed Mar 29 20:32:31.307 <kernel> IO80211ScanManager::cachePurge: clearEntries[0] Firing!
Wed Mar 29 20:32:31.307 <kernel> IO80211ScanManager::cachePurge: Rescheduling in 16 seconds.
Wed Mar 29 20:32:47.309 <kernel> IO80211ScanManager::cachePurge: clearEntries[0] Firing!
Wed Mar 29 20:32:47.309 <kernel> IO80211ScanManager::cachePurge: Rescheduling in 1 seconds.
Wed Mar 29 20:32:48.310 <kernel> IO80211ScanManager::cachePurge: clearEntries[0] Firing!
Wed Mar 29 20:32:48.310 <kernel> IO80211ScanManager::cachePurge: NOT Rescheduling.
Time elapsed, 1 minute 48 seconds, 241 lines of entries added to the wifi.log file, for a product, that as far as I can see, has no need for any interaction with the wifi hardware (or indeed the network at all).
