Problems with Gigapan Import
Aeriscera
by Aeriscera » Thu Mar 02, 2017 5:08 pm
I tried importing a 27 by 8 array of HDR files in APG 3.7 and got the following result:
Clearly there's a problem on the left hand side of the image. I used the Gigapan Import dialog, selected the right dimensions and pressed "OK". Have I unwittingly entered the wrong parameters again? (viewtopic.php?f=19&t=35005).
The files (216, 10GB) will be here in due course if you would like to try them.
olivierbo
Liked in: 133 posts
Re: Problems with Gigapan Import
by olivierbo » Tue Mar 07, 2017 2:31 pm
Why are you using hdr rather than jpeg or tiff? How do you process your bracketed pictures?
Anyway, you can use the .pano file attached.
Cheers,
Olivier
[Group 2]-big001_2_3_big646_7_8-216 images.pano
(2.87 MiB) Downloaded 84 times
