Weird Colors
Smera
Weird Colors
by Smera » Sat Feb 25, 2017 4:08 pm
I am new to AutoPano and have an issue with weird colors like this. Can someone help me? Thanks.Image
Re: Weird Colors
by Annis » Mon Feb 27, 2017 4:05 pm
If you are using Sierra, make sure you use the beta version (Autopano 4.4) as any version before that does not support Sierra and I've seen reports of similar issues.
Moving your topic to the Autopano forum.
Smera
Re: Weird Colors
by Smera » Mon Feb 27, 2017 8:18 pm
Hi Annis,
Thank you very much! The issue was solved and now the images are properly rendered.
Smera
Re: Weird Colors
by Smera » Mon Feb 27, 2017 8:59 pm
Just one more question: now I have two AutoPano plug-in extensions in Bridge CC (2017) Tools Menu. How Can I do to get rid of the Autopano 4.2 from the tools menu? Many Thanks.
Re: Weird Colors
by Annis » Tue Feb 28, 2017 3:41 pm
Have you uninstalled Autopano 4.2?
Smera
Re: Weird Colors
by Smera » Tue Feb 28, 2017 6:16 pm
Yes I did.
Re: Weird Colors
by Annis » Thu Mar 02, 2017 10:22 am
Hmm well these are the steps to install the Bridge plugin if it didn't install, you should be able to go to the same filepath and remove the ones you don't want to keep.
