APG Crashes on Launch   [SOLVED] - View the solution
BobF
by BobF » Wed Feb 01, 2017 9:58 pm
I had to reformat and reinstall my OS and revert back to Win7 from Win10 (perhaps the worst piece of software MS has created, yes, maybe even worse than ME and Vista). Also, obviously, have had to reinstall all my software applications.
Running Win7 SP1, with all updates completed, 16GB of RAM, AMD 8-core processor.
I have downloaded and installed my version of APG (2.0). When I try to launch the application, it crashes immediately. There is no error message, but there are references to files in the Temp directory. The .txt file is attached for reference.
Thoughts appreciated.
Thank you.
WERF596.tmp.appcompat.txt
(26.54 KiB) Downloaded 43 times
