Pano file not saving correctly   [SOLVED] - View the solution
marzipano
Liked in: 14 posts
by marzipano » Sun Oct 30, 2016 12:16 pm
I am using APG 4.2.3 under Windows 10 build 1607 on a 64bit ASUS laptop with 12GB RAM
I have come across a problem saving pano files
This seems to apply to at least APG4.2.2 and 4.2.3 and on a number of sub-folders I tried + desktop
It seems as though when the pano projection is amended (e.g from cylindrical to spherical) during an edit, then when a SAVE or SAVE AS is used to store the contents of the .pano file, APG hangs and has to be closed forcefully. It creates a .pano file of 0 bytes
When the default projection is used it appears to work OK and the .pano file is saved correctly
I also had one change of projection of cylindrical to mercator and back to cylindrical that also seemed to be OK so it may be that only certain combinations cause the problem. I know switching from cylindrical to spherical and also planar to cylindrical cause the issue as I tested both these
I attach some pano files - 2 OK and 2 zero length ones - I added one char to get it to upload
best
Martin
marzipano
Liked in: 14 posts
Re: Pano file not saving correctly  [SOLVED]
by marzipano » Mon Oct 31, 2016 6:15 pm
I have been using APG again today and this "bug" seems to have gone away of its own accord so it may have been something else causing it on my own laptop.
I am flagging as solved but will re-raise if I spot it again
Martin
