Blurred pictures when mixing the hole panorama (preview on).
Ernesto
Likes: 9 posts
by Ernesto » Tue Jul 26, 2016 5:56 am
Ok.
I worked with 69 images in 23 stacks, 3.44 RMS and 100% overlapping. BUT... images look blurred :O (screenshot with the red oval)
Then...
I took 3 of the same images of those 69 and worked with them and they match perfectly. (screenshot with the green oval)
Why is that? :O
I took all the images with tripod, no movement in any when looking at each one of them separately
Button preview is pressed.
Here you have the screenshots
Please... help, help, help...
mac overview.png (24.93 KiB) Viewed 821 times
autopano pro 4.2.png (24.12 KiB) Viewed 821 times
olivierbo
Liked in: 134 posts
Re: Blurred pictures when mixing the hole panorama (preview
by olivierbo » Tue Jul 26, 2016 12:06 pm
Click the Blend tool to be sure the preview is enabled. That being said, once you click the preview button, you can see a green rectangle:
marzipano
Liked in: 14 posts
by marzipano » Tue Jul 26, 2016 1:59 pm
olivierbo wrote:Hello,
If there is insufficient resources to process the whole blended panorama then when you select fusion the red rectangle around the preview image will stay red instead of going to green. This will then not give correct results
