Don't start on Ubuntu 16.04 Xenial   [SOLVED] - View the solution
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue May 03, 2016 5:35 pm
Hi
Autopano Giga refuses to start on the new release of Unbutu, the 16.04 Xenial. There is a dependency issue I could resolve with symlink but there is a more serious problem with QT dependencies:
vincen@portable-ubuntu:~$ AutopanoGiga
/usr/lib/AutopanoGiga/AutopanoGiga: symbol lookup error: /usr/lib/AutopanoGiga/libQt5Core.so.5: undefined symbol: ucnv_getDefaultName_52
A way to avoid that problem ? or wait for an update of APG ? ;)
Vincèn
Blog: http://www.skivr.com
olivierbo
Liked in: 133 posts
Re: Don't start on Ubuntu 16.04 Xenial
by olivierbo » Wed May 04, 2016 9:02 am
Have you tried to install the tar.gz package?
Kind regards,
Olivier
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed May 04, 2016 10:12 am
olivierbo wrote:Have you tried to install the tar.gz package?
vincen@portable-ubuntu:~/Bureau/AutopanoGiga$ ./AutopanoGiga
./AutopanoGiga: error while loading shared libraries: libKGFL_linux64.so: cannot open shared object file: No such file or directory
I made a quick search but didn't find any missing package in my distro about libKGFL :( Someting else to test ?
dim
by dim » Fri Jun 03, 2016 9:49 pm
I have the same problem. Autopanopro need libicu52. In Xenial, it's libicu55!
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Jun 06, 2016 4:58 pm
Problems corrected with latest beta of AVP ;)
Thanks Kolor :)
ClaireM
Liked in: 36 posts
Re: Don't start on Ubuntu 16.04 Xenial  [SOLVED]
by ClaireM » Fri Jun 10, 2016 8:23 am
Hi guys,
This problem has indeed be solved in the latest version of AVP. In case you are not using AVP and only APG (or APP), here is what you can do to enable it on Ubuntu 16.04 :
The missing libraries are included in the *.tar.gz archive but not in the *.deb archive.
--> So if you want, you can download the tar.gz, uncompress it and use it straight from here with :
sh path/to/targzarchive/AutopanoGiga.sh
--> If you still want to use the deb file, download the *.deb and install it. Download the tar.gz archive, uncompress it, locate the libraries named : libicudata.so.52, libicui18n.so.52, libicuuc.so.52 and copy them into /usr/lib/AutopanoGiga
(or /usr/lib/AutopanoPro for the standard version ).
To have the right copy permissions, do it through a terminal with :
sudo cp path/to/targz/archive/libicu* /usr/lib/AutopanoGiga
And Autopano should work like a charm....
Sorry for the inconvenience,
Best,
Claire
vincen likes this post.
