Problem to import png files as Patch ! (Follow-up)   [SOLVED] - View the solution
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Dec 14, 2015 3:02 pm
After initial thread here (viewtopic.php?f=19&t=29490), problem still there :( PNG opened in Gimp, converted to RVB and Exported for Web in Gimp selecting Web profile for color and refused in APG for Nadir patch :(
Blog: http://www.skivr.com
vincen
Likes: 23 posts
Liked in: 4 posts
Re: Problem to import png files as Patch ! (Follow-up)  [SOLVED]
by vincen » Mon Dec 14, 2015 3:03 pm
In fact when you Export for Web with Gimp, whatever you select Web colors it still creates a custom one and don't use the RGB standard so you have to select Export instead :)
