Problem to import png files as Patch !   [SOLVED] - View the solution
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Dec 14, 2015 11:00 am
Hi
Using APG 4.2.3 on Ubuntu 14.04 64 bits, I encounter lot of problems importing patch image in APG. With JPG it works most of time but with PNG files most of time it doesn't work ! I select file to add in the layer editor, then I see very briefly the blue bar at the bottom left moving and then done, picture not added at project :(
I attach a sample of a png file not working.
png file not accepted as patch in APG
Vincèn
Blog: http://www.skivr.com
Re: Problem to import png files as Patch !
by Annis » Mon Dec 14, 2015 11:55 am
Curious.
Could you try another .png patch, for example this one and tell me if it works?
Sans titre2.png (145.82 KiB) Viewed 1686 times
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Dec 14, 2015 12:32 pm
Annis wrote:Curious.
I tried with few different PNG without much success in fact ! Most of my PNG are done or saved with Gimp. May it be the origin of the issue ?
Works like a charm with your PNG file ;)
by Annis » Mon Dec 14, 2015 1:11 pm
My PNG was also created in GIMP.
Trying to find the difference between the two...
Re: Problem to import png files as Patch !  [SOLVED]
by Annis » Mon Dec 14, 2015 1:17 pm
Try this, the colour profile was switched to RVB :
(For future reference, here's where to change it in GIMP)
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Dec 14, 2015 1:44 pm
Annis wrote:Try this, the colour profile was switched to RVB :
Very good idea, didn't think about it and it's the trick ;) Might be nice that either APG converts to RGB if needed automatically or issues a warning about file that has to be in RGB instead of silently failing :cool:
