Autopano 4.2.3 libKGFL_linux64.so missing
hannes
by hannes » Thu Dec 10, 2015 6:29 pm
I wanted to upgrade to Autopano Giga 4.2.3 (ubuntu 12.04) but the new version is not running complaining: error while loading shared libraries: libKGFL_linux64.so: cannot open shared object file: No such file or directory
Autopano Giga 4.2.2 is working
ClaireM
Liked in: 36 posts
Re: Autopano 4.2.3 libKGFL_linux64.so missing
by ClaireM » Fri Dec 11, 2015 3:01 pm
Are you using the deb file or the *.tar.gz file?
Let us know,
Best,
Claire
hannes
by hannes » Fri Dec 11, 2015 3:45 pm
I am using the deb file.
Best Regards
Hannes
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Dec 14, 2015 10:56 am
hannes wrote:I am using the deb file.
Did you try to uninstall first the previous version using the package manager (dpkg ou apt-get) ? sometimes it helps ;)
Blog: http://www.skivr.com
hannes
by hannes » Mon Dec 14, 2015 11:54 am
thank you for that hint - I did this - but now I get a new message:
hannes@Sugo1:~/Arbeitsfläche$ AutopanoGiga &
[1] 9664
hannes@Sugo1:~/Arbeitsfläche$ This application failed to start because it could not find or load the Qt platform plugin "xcb".
Available platform plugins are: xcb.
Reinstalling the application may fix this problem.
/usr/bin/AutopanoGiga: Zeile 4: 9665 Abgebrochen (Speicherabzug geschrieben) /usr/lib/AutopanoGiga/AutopanoGiga "$@"
hannes
by hannes » Mon Dec 14, 2015 12:04 pm
next try: tar.gz
/home/xyz/SOFTWARE/TMP/AutopanoGiga/AutopanoGiga: error while loading shared libraries: libKGFL_linux64.so: cannot open shared object file: No such file or directory
but in fact the file is there and executable ...
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Dec 14, 2015 12:36 pm
hannes wrote:thank you for that hint - I did this - but now I get a new message:
[1] 9664
try this in a terminal:
sudo apt-get install libx11-xcb1
it'll install a package that might be missing on your system (not sure if it's avalaible in standard repositories of Ubuntu 12.04 but no risk to try it ;)
hannes
by hannes » Mon Dec 14, 2015 2:00 pm
already installed ...
ClaireM
Liked in: 36 posts
by ClaireM » Mon Dec 14, 2015 7:34 pm
When the deb is installed, what is the output of the following command :
ls /usr/lib/AutopanoGiga/
Also, about the problem you're experiencing with the tar.gz, just try to re-download it from the Kolor website, and let me know about the result.
(NOTE : it is highly recommanded to use ubuntu 14.04 LTS since it is on this system that Autopano is tested)
Best,
Claire
hannes
by hannes » Mon Dec 14, 2015 9:36 pm
1
AutopanoGiga libQt5Qml.so.5
KCrashReporter libQt5Quick.so.5
libiomp5.so libQt5Svg.so.5
libKGFL_linux64.so libQt5Widgets.so.5
libKMath_3rd_linux64.so libQt5XcbQpa.so.5
libQt5Core.so.5 libQt5Xml.so.5
libQt5DBus.so.5 libtbb.so.2
libQt5Gui.so.5 platforms
libQt5Multimedia.so.5 Plugins
libQt5Network.so.5 Resources
libQt5OpenGL.so.5 xcbglintegrations
2
./AutopanoGiga.sh
hannes@Sugo1:~/SOFTWARE/TMP/AutopanoGiga$ This application failed to start because it could not find or load the Qt platform plugin "xcb".
ClaireM
Liked in: 36 posts
by ClaireM » Mon Dec 14, 2015 10:24 pm
Thanks,
Also can you confirm that you are not running on some "unusual configs" like a virtual machine or so?
What is your GPU? Which driver are you using in to run it?
Also did you have by any chance a version of Qt installed somewhere on your computer?
Best,
Claire
hannes
by hannes » Mon Dec 14, 2015 10:46 pm
no "unusual configs" as far as I know
How to test or show info on the gpu?
How to test or show info about the Qt version?
here is the gpu - info
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Dec 15, 2015 7:52 am
hannes wrote:How to test or show info on the gpu?
You can usi I-Nex program to get all detailed infos about your computer hardware: http://i-nex.linux.pl/install/ including QT version(s) installed on your system !
hannes
by hannes » Tue Dec 15, 2015 9:48 am
installation worked but I got an error:
Fehler traten auf beim Bearbeiten von:
i-nex
E: Sub-process /usr/bin/dpkg returned an error code (1)
i-nex is running and I found information about the GPU but where to find information about the QT-versions?
ClaireM
Liked in: 36 posts
by ClaireM » Tue Dec 15, 2015 9:53 am
As for the deb :
I think I did get what is the issue here : what is the way you're lauching the deb file?
If I do :
'cd /usr/lib/AutopanoGiga/' and then './AutopanoGiga' I am getting the issue you're having : ./AutopanoGiga: error while loading shared libraries: libKGFL_linux64.so: cannot open shared object file: No such file or directory
(Indeed, with this way you're skipping the prelaunch script that sets all the environment path correctly for Autopano Giga to found the library it needs).
What you need to do from wherever on your system is opening a terminal and run this command : 'AutopanoGiga'
Let me know about the result.
As for the tar.gz :
Can you go where you uncompressed your archive and try the following commands :
gedit AutopanoGiga.sh
Change you file so that is looks like the following (only 4 last lines were changed) :
#!/bin/sh
appname=`basename $0 | sed s,\.sh$,,`
dirname=`dirname $0`
LD_LIBRARY_PATH=$dirname
export LD_LIBRARY_PATH
export QT_PLUGIN_PATH="$dirname"
for f in *.so*; do echo $f; ldd $f | grep -i xcb; done
for f in ./platforms/*.so*; do echo $f; ldd $f | grep -i xcb; done
for f in ./xcbglintegrations/*.so*; do echo $f; ldd $f | grep -i xcb; done
#ldd $dirname/$appname "$@" &
Save the result, run sh AutopanoGiga.sh and post the output (or PM me the output cause it is likely to be quite long).
Best,
Claire
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Dec 15, 2015 10:01 am
hannes wrote:i-nex is running and I found information about the GPU but where to find information about the QT-versions?
System tab -> Library !
Did you try to run program directly from the Unity launcher by just typing Auto ?
hannes
by hannes » Tue Dec 15, 2015 10:36 am
Hi Claire,
As for the .deb
I always did I the way you said I should do it:
/usr/bin/AutopanoGiga: Zeile 4: 10196 Abgebrochen (Speicherabzug geschrieben) /usr/lib/AutopanoGiga/AutopanoGiga "$@
concerning the tar.gz:
hannes@Sugo1:~/SOFTWARE/TMP/AutopanoGiga$ ./AutopanoGiga.sh
libKGFL_linux64.so
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fc90944a000)
libQt5Core.so.5
libQt5DBus.so.5
libQt5Gui.so.5
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fb568336000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f0146b18000)
libQt5Network.so.5
libQt5OpenGL.so.5
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f81b2f47000)
libQt5Qml.so.5
libQt5Quick.so.5
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fe73f39f000)
libQt5Svg.so.5
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f178f0fa000)
libQt5Widgets.so.5
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007feee3520000)
libQt5XcbQpa.so.5
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f5eb5796000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f5eb4f46000)
libQt5Xml.so.5
libicudata.so.52
libicui18n.so.52
libicuuc.so.52
libiomp5.so
libtbb.so.2
./platforms/libqxcb.so
libQt5XcbQpa.so.5 => ./libQt5XcbQpa.so.5 (0x00007fa3696af000)
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007fa368206000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fa3679b6000)
./xcbglintegrations/libqxcb-egl-integration.so
libQt5XcbQpa.so.5 => ./libQt5XcbQpa.so.5 (0x00007f95fdcd1000)
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f95fbee5000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f95fb695000)
libxcb-dri2.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0 (0x00007f95fa5ab000)
libxcb-xfixes.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0 (0x00007f95fa3a4000)
./xcbglintegrations/libqxcb-glx-integration.so
libQt5XcbQpa.so.5 => ./libQt5XcbQpa.so.5 (0x00007fa1e6049000)
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007fa1e4289000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fa1e3a39000)
hannes
by hannes » Tue Dec 15, 2015 10:39 am
hi vincen,
there is a second programm i-nex library - here is the screenshot
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Dec 15, 2015 10:45 am
hannes wrote:there is a second programm i-nex library - here is the screenshot
Did you try to run it directly from Unity launcher ?
hannes
by hannes » Tue Dec 15, 2015 10:49 am
no, i am not using unity
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Dec 15, 2015 10:52 am
hannes wrote:no, i am not using unity
oki but you can try it in your launcher no ? which one is it ?
ClaireM
Liked in: 36 posts
by ClaireM » Tue Dec 15, 2015 10:57 am
Hi again,
Hannes, I thought that with the deb file, the issue was with libKGFL ? Whereas with the tar.gz the issue was something dealing with xcb...
Given your previous post, it seems that now both of your issues (deb and tar.gz) are related to xbc, is that right? (Sorry, but I'm getting confused by the errors).
Best,
Claire
hannes
by hannes » Tue Dec 15, 2015 11:07 am
Yes - seems to be so - the messages changed after deleting and reinstalling (the procedures mentioned above).
I am confused too.
Maybe it is the best to stay with version 4.2.2. and later update to ubuntu 14.04 LTS ...
best regards
hannes
ClaireM
Liked in: 36 posts
by ClaireM » Tue Dec 15, 2015 11:12 am
I mean, we had issues with xcb earlier, are you displaying through VGA or HDMI ? Does your display setup have anything noticable? ... for sure the best thing to do would be to use a fresh install of Ubuntu 14.04, although the problem you have should not occur...
EDIT : Can you try this :
sudo apt-get install "^libxcb.*" libx11-xcb-dev libglu1-mesa-dev libxrender-dev libxi-dev
(Just to make sure you have all dependencies installed for xcb)
Best,
Claire
hannes
by hannes » Tue Dec 15, 2015 11:35 am
the monitor is connected via diplayport
something concerning xcb was installed
trying to run AutopanoGiga
the error massage is the same
