APG on Ubuntu Wily 15.10, wants libicui18n.so.52
bradtem
by bradtem » Sun Dec 06, 2015 6:16 pm
I just upgraded to the latest Ubuntu (15.10 wily werewolf) on AMD64 and also upgraded my APG to 4.23. Unfortunately it fails to start, saying:
AutopanoGiga: error while loading shared libraries: libicui18n.so.52: cannot open shared object file: No such file or directory
On the system there is libicui18n.so.55 (and 55.1) but 52 is an old version no longer supported, it seems. It is no longer in the apt repository either.
ClaireM
Liked in: 36 posts
Re: APG on Ubuntu Wily 15.10, wants libicui18n.so.52
by ClaireM » Mon Dec 07, 2015 9:10 am
You can try this workaround :
-> In a terminal enter the following commands :
wget http://security.ubuntu.com/ubuntu/pool/ ... _amd64.deb
dpkg -i libicu52_52.1-8ubuntu0.2_amd64.deb
Let us know about the result,
Best,
Claire
(NOTE : this is a workaround for 15.10, however it is clearly indicated that APG was only tested on Ubuntu 14.04 LTS)
bradtem
by bradtem » Mon Dec 07, 2015 6:21 pm
Understood. Though generally it looks like APG may be doing its bindings too tightly, since most programs are capable of running on newer releases if they are designed and tested on an older release.
I would strongly suggest to Kolor that the most common and probably best way to support Ubuntu is with a "PPA" which will make it install, calculate the dependencies, and also allow us to automatically upgrade as compatible new versions come out. It is the official way -- a hand downloaded deb is the kludge approach.
bradtem
by bradtem » Mon Dec 07, 2015 6:25 pm
Also, while this worked, once again it forgot all my settings. I know it does this on major version upgrades but it should not, an definitely not on minor version upgrades. Or perhaps you can work out a more portable format to store settings in.
