Minimum tool panel width far too wide
DrSlony
by DrSlony » Sun Nov 29, 2015 6:12 pm
The minimum width of the panel which shows you controls of the tool you're currently using in the "Edit panorama" window is far too wide.
Example with the "Move" tool:
http://i.imgur.com/d0fBLGs.jpg
Furthermore, not only is it far too wide but the arrangement of the contents of this panel is not fluid. There is no need for that huge gap between the labels on the left and the icons on the right.
APG-4.* in Linux.
ClaireM
Liked in: 36 posts
Re: Minimum tool panel width far too wide
by ClaireM » Mon Nov 30, 2015 9:29 am
This is a known issue (5343), however impossible to reproduce over here.
I'll let you know if I can get further info.
Best,
Claire
DrSlony
by DrSlony » Mon Nov 30, 2015 3:18 pm
Great that it's on your radar. I've always had it regardless of window manager - KDE4, KDE5, Awesome, and possibly E17.
Maybe it will help you reproduce the problem by knowing that I always use the "LINUX .TAR.GZ 64" version and run the ./AutopanoGiga.sh file.
ClaireM
Liked in: 36 posts
by ClaireM » Mon Nov 30, 2015 3:36 pm
Indeed, I even think it's not linux specific (we had similar issue on macos and windows).
What is the display resolution you're using? (I think its related to small screens but not sure though).
DrSlony
by DrSlony » Mon Nov 30, 2015 3:40 pm
1920x1080
DrSlony
by DrSlony » Mon Nov 30, 2015 3:47 pm
Here is my configuration file (sans key and recent folders)
http://filebin.net/qx5ov9pbpf/Autopano_Giga_4.2.conf
