Destiny wrote:Where.. I cannot get this option to show.. Only get N_0 to N_4....
How did you get the shutter speed....
Destiny wrote: Clearly there is something not right with APG..
Destiny wrote:I will have to continue with this in the morning.. Getting late down under...
Thank you for all your testing guys. Clearly there is something not right with APG.. I have found it tends to remember stuff which causes issues.. Like having its own little Cache..
Destiny wrote:I really do believe there is a missing option with Stacks and Fusion. It does not remove ghosting.. If I add my pre-fused images and zoom into an area of concern, then press Preview, you can see the double imaging being removed, but that is not the case with stacked images. The double imaging remains into the rendering. I can see moment in my images in part when I flick between slices in Edit. The question is; Is it my NPP out or movement of my tripod moving.. Perhaps some long term issues I have had comes down to my tripod moving.. It is very light..
What would be the best Tripod to buy??. I still have my birthday money which I was wanting to buy a Pole and WiFi memory card with.. but.. perhaps a heavy tripod would be a better option....
I have just added another pano pre-fused set into APG and one half of the pano as no moments between slices but the other half does.. I think you are right about my tripod being an issue Klaus. If my NPP was out then I should get moment across the entire panos. Not just random parts of it..
APG does a very good job of removing double imaging but only when adding pre-fused images. It fails to remove it with stacks. Unless I am doing something wrong...
Destiny wrote:Probably other areas too.. I would have thought that APG could fix that..
Destiny wrote:As it is, I have stitching errors but no double ghosting.... So can you guys use EnfuseGUI all defaults with my medium sized images and tell me what settings are best to use with my images..
klausesser wrote:As long as you let others do the findings you´ll never achieve the insight you need to use this things successfully, sorry.
Destiny wrote:What would be the best Tripod to buy??. I still have my birthday money which I was wanting to buy a Pole and WiFi memory card with.. but.. perhaps a heavy tripod would be a better option....
klausesser wrote:
Had you NOT chosen "hard linking" but "look for CPs" (or so) the CP-detection would have worked on EACH of the five image-layers. This takes definitely longer - but could handle moving parts in the bracketed sets.
mediavets wrote:If APG cannot handle anti-ghost both within and between stacks with exposure fusion, then it seems third party processing is a better option
Destiny wrote:Thank you for those links.. I like the Gitzo but I really want flat feet.. I am sure that my rounded feet can cause some issues.. I have seen my tripod spring out its legs just a little bit during shooting on tiles..
Destiny wrote: but not so sure in the case of my Antique Centre shoot.. I did not see it move..
Destiny wrote:
There is the Series 3, is this not any good..
http://www.bhphotovideo.com/c/product/8 ... MATIC.html
The total weight of my gear is around 4.7kg.. So 5kg max..
Destiny wrote:I did not know that in Live View the Mirror locks.... Why... I do know that the shutter is a lot slower in Live View...
Destiny wrote:I cannot leave my camera with Live View when my VR Drive has the HDR cable attached... As soon as I atteach the cable Live View shuts off... Not sure if I can over ride it...
mediavets wrote:Klaus,
I have neither, but I have read that D800 mirror lock up capabilities are as not as good as those on high end Canons.
Are you talking of the D800 or a Canon body?
mediavets wrote:I have a Promote Control and the qDSLRdashboard (running on Nexus 7 Android tablet) with WiFi router device; both work fine with my D5100. But the D5100 doesn't offer the mirror lock up features of the D800 so I don't know whether they would work with that feature of the D800.
mediavets wrote:But I can understand why Destiny finds the notion of the 'built-in' exposure bracketing control of the VRDDrive 2 attractive.
