APG4 problems
GIGAmacro
APG4 problems
by GIGAmacro » Thu Apr 02, 2015 10:52 pm
We are running a large stitch form our Terabite project. These have been stitched with APG 3, and we are trying 4 to see if the results are better. They are disastrously worse! And we can't see why.
Here is the result:
Note especially that the FOV is assumed to be square in the result - and a requirement for over 2TB of space to output?
Any help appreciated.
________________________________
GIGAmacro
Exploring Small Things in a Big Way
t: giga_macro
w: www.gigamacro.com
HansKeesom
Re: APG4 problems
by HansKeesom » Mon Apr 06, 2015 10:36 am
Of course you can reduce the % from 100% to 50%. This will problably generate a 500 MB file.
Or select a different drive then your E-drive.
2 TB is not that strange considering you use 1600 images.
GIGAmacro
Re: APG4 problems
by GIGAmacro » Mon Apr 06, 2015 2:49 pm
Understood. That's actually less of an issue that the fact that it stitched in 3.7.1 and will not in 4.
GIGAmacro
t: giga_macro
HansKeesom
Re: APG4 problems
by HansKeesom » Mon Apr 06, 2015 2:53 pm
it is problably in the settings. Open both version next to one another and compare all the settings.
GIGAmacro
Re: APG4 problems
by GIGAmacro » Mon Apr 06, 2015 4:27 pm
Done that! They are identical.
GIGAmacro
t: giga_macro
HansKeesom
Re: APG4 problems
by HansKeesom » Thu Apr 09, 2015 7:38 am
Well, be pragmatic then. If something does not stitch in 4.0 try it in 3.7.1. As long as you have a good result, you are fine ;-)
Finding out why it won't stitch in 4.0 can take a long while. Upload the files to kolor so they can have a try. Don't spend your time on it.
GIGAmacro
Re: APG4 problems
by GIGAmacro » Thu Apr 09, 2015 7:59 am
How do we upload files to Kolor?
GIGAmacro
t: giga_macro
ThomasV
Re: APG4 problems
by ThomasV » Thu Apr 09, 2015 9:35 am
you can use our FTP server.
Details in this post: http://www.kolor.com/forum/viewtopic.php?f=3&t=766
Regards,
Thomas
GIGAmacro
Re: APG4 problems
by GIGAmacro » Thu Apr 09, 2015 3:07 pm
Thanks!
GIGAmacro
t: giga_macro
Re: APG4 problems
by gkaefer » Mon Apr 13, 2015 7:12 pm
Change from 3.7.1 to 4.0...
... from previous Major changes I know that the way how you upgraded your Software may massivly Impact the resulting Quality of the new apg Version.
in case you had 3.7.1 installed and you changed somehow in the past the Default Settings and you now just upgraded to 4.0 using the built in upgrade possibility:
1. do an uninstall via window programs uninstall Option (do not Keep Settings if you get asked)
2. reboot Windows pc
3. download 4.0 manually & install apg 4.0 (run as admininstator...)
4. give your pano a new try (without using saved Project files....)
