[Win7 64bit] APG freezes when lens profile is selected.
planb
Likes: 4 posts
by planb » Tue Mar 31, 2015 9:46 am
Hi everyone,
my APGcrashes when I try and select the lens profile (Tokina 11-16 f2.8 DX) from the adobe lightroom lens profiles. It freezes both on APG 4.00 RC1 and APG 3.7.1. It freezes immediately once I selected it from the explorer window and clicked on open.
I use a 32 core 32 gig CADnetwork ProViz W60 workstation with an up to date win 7 SP1.
HansKeesom
Re: [Win7 64bit] APG freezes when lens profile is selected.
by HansKeesom » Mon Apr 06, 2015 10:37 am
Are you able to upgrade to the final release?
planb
Likes: 4 posts
by planb » Tue Apr 07, 2015 9:33 am
yes, but it still freezes once i select the profile
ClaireM
Liked in: 36 posts
by ClaireM » Fri Apr 10, 2015 2:07 pm
Hi planb,
The freeze that you experiment is due to the fact that some of the lense profile files (*.lcp files) have changed and are not supported by Autopano's OpenLens plugin yet. What you can do instead :
--> Correct your lense distortions, chromatic aberrations and vignetting using another software (Camera Raw, Lightroom...) and import the corrected pictures to Autopano.
OR
--> Since Autopano's optimizer estimates lens distortions and can correct color and vignetting failures, you can directly try to stitch your panorama without additional correction on your pictures.
Best,
Claire
