difference between preview and rendering: duplicate object
Chrisllers
by Chrisllers » Fri Oct 10, 2014 10:22 am
hi,
i'm using autopano giga and i have a problem.
This is what i can see before rendering. As you can seen in the red circle, there is only one tower.
But after rendering, this object is duplicate and i have two towers :
What happened ? How can i solve this problem ?
Re: difference between preview and rendering: duplicate obje
by Destiny » Fri Oct 10, 2014 1:51 pm
Hi.. Did you set Anti Ghost...
marzipano
Liked in: 14 posts
by marzipano » Fri Oct 10, 2014 2:02 pm
That looks like quite a major parallax issue - images taken from different viewpoints
In particular look at the conical mountain feature just to the left of the base of the tower in both images and see the difference in relative positioning compared with the tower base
Switching on "multiple viewpoints" might help
by klausesser » Fri Oct 10, 2014 4:40 pm
Chrisllers wrote:hi,
You could try masking in one of the overlapping areas. Or you can try to manually edit the control-points related to the
object.
by Destiny » Fri Oct 10, 2014 10:36 pm
Did you shoot this pano by hand.. There seems to be so many mismatches.. This might help but it will requires a lot of hand editing... You should be able to achieve the same results as in the preview.... http://www.autopano.net/wiki-en/action/ ... Anti-Ghost
