Hard to stitch pano
DrSlony
Hard to stitch pano
by DrSlony » Fri Sep 26, 2014 7:08 pm
Hey!
Autopano Giga 3.6.3 leads to a garbage stitch on this image set even though the photos are correctly shot round the NPP. If I enable "Layout > Single row or column" then they stitch correctly.
Maybe you can use them when tweaking future engine versions.
I have included my settings file.
I am uploading the archive to your FTP, the filename is:
2014-09-25 remont.7z
Kind regards
Re: Hard to stitch pano
by Destiny » Fri Sep 26, 2014 8:36 pm
Did you try ... ISO
DrSlony
by DrSlony » Fri Sep 26, 2014 8:45 pm
Hi
I recall some mode called ISO, but can't find it in 3.6.3. Perhaps it was renamed to something else?
Anyway this isn't about trying to get a stitch - it stitched fine when using "single row or column". I'm just hoping to help Kolor improve the automatic algos of APG by providing this case :]
by Destiny » Fri Sep 26, 2014 8:53 pm
I see... Lionel will probably play with your images.. As for ISO, its in the Render Tab, Advanced settings, replace Smart to ISO.. Its works a lot like PTGui.. To be honest, I am using a Robotic Head and fail to understand why the Smart or does not work for my images.. Lionel has said that my NPP is perfect.. So I wonder why I need to use ISO... It does not matter whether I pre-fuse my images or use stacks.. I get the same missed stitching results...
DrSlony
by DrSlony » Fri Sep 26, 2014 9:09 pm
Ah, I see. No, this is not about stitching errors during rendering which the ISO setting could indeed influence, but about the stitch itself.
marzipano
Liked in: 14 posts
by marzipano » Fri Sep 26, 2014 10:13 pm
DrSlony wrote:Hey!
Kind regards
Only Kolor staff can see that FTP location
If you want other Forum members to comment you need to upload to something like Dropbox and put a public link on the forum (unless you specifically only want Kolor to look at the problem)
Martin
DrSlony
by DrSlony » Sat Sep 27, 2014 10:48 am
I do not.
DrSlony
by DrSlony » Tue Oct 07, 2014 12:05 pm
Kolor: I kind of forgot to start the FTP upload process until today :cool:
The upload has completed, please let me know if you got it correctly (MD5 included).
