AutopanoPro_Linux64_363_2014-08-06 doesn't install
dim
by dim » Wed Aug 20, 2014 3:54 pm
The terminal: "(Reading database ... 282880 files and directories currently installed.)
Preparing to replace panotour 200RC1 (using .../Panotour_Linux64_220_2014-07-28.deb) ...
Unpacking replacement panotour ...
dpkg-deb (subprocess): decompressing archive member: lzma error: compressed data is corrupt
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dpkg: error processing /home/dim/Desktop/Panotour_Linux64_220_2014-07-28.deb (--install):
cannot copy extracted data for './usr/lib/Panotour/libmcplugcore.so.3.3.1.15702' to '/usr/lib/Panotour/libmcplugcore.so.3.3.1.15702.dpkg-new': unexpected end of file or stream
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for man-db ...
Errors were encountered while processing:
/home/dim/Desktop/Panotour_Linux64_220_2014-07-28.deb"
I't the same with Panotour_Linux64_220_2014-07-28... but not with older packages.
Ubuntu 13.04 & 14.O4
AntoineM
Re: AutopanoPro_Linux64_363_2014-08-06 doesn't install
by AntoineM » Thu Aug 21, 2014 12:54 pm
It seems that the package fail to download completely some times, resulting in this kind of corruption error during installation.
Please try the solution provided in the paragraph "If the software was obtained from the Internet" of this page: http://nsis.sourceforge.net/Why_do_I_get_NSIS_Error
Best regards,
Antoine
dim
by dim » Thu Aug 21, 2014 3:08 pm
NSIS is for windows? No?!
AntoineM
by AntoineM » Thu Aug 21, 2014 3:46 pm
Yes of course but this troubleshooting also applies to your linux error as the source issue seems to be the same (the download).
by AlexandreJ » Thu Aug 21, 2014 4:02 pm
dim wrote:...
This is the issue, the downloaded package is corrupted.
